Nitrous Users Check In
2k1civic.com O. G.
ok ive been considering nitrous for many reasons. the main reason being cost, and potentially lower maintenance becuase i will probably rarely use it becuase i only goto the trrack once in awhile. also i just wanted to see if anyone has experience any major headaches after using it for awhile, say like a few times a week.
so:
what kit do you have?
manual or auto?
how long have you had it installed?
how often do you use it?
any signs of wear or abnormalty of engine?
maintence that you have done on your car becuase of nitrous?
mods you have?
numbers if any?
1/4 times if any?
thanks
Mike
so:
manual or auto?
mods you have?
numbers if any?
1/4 times if any?
thanks
Mike
Zex Wet Kit
Auto
still sitting in my room bc i just got it yesterday and wont have time to install it for a month or so
Auto
2k1civic.com O. G.
do u think its necessary to get a tranny cooler for a 55+ shot? ive seen some at www.jegs.com but i dont know which is good. ive also read on www.honda-tech.com that cooling the tranny too much is also just as bad as it over heating. from what im reading optimal temp is like 175F.
im also worried about spraying at full throttle during shifts. i heard that u can get a window switch so that it only sprays wen armed and at full throttle between desired RPM's. does the zex kit have anything like that? whats involved in setting something like that up.
7thgen Man-gina
7thgen Nitrous FAQ ohh yeah, i wrote it
i spray more than i should. im lookin to get some colder plugs. and i have no idea on how to retard the timing. does anyone know how to do this
yeah i have the aem cam gear laying around my room somewehere. ill probobly put the cam gear on and the kms intake manifold at the same time
No no no!!! you dont retard timing like that. That retards valve timing, but what you need to do is retard the ignition timing. And right now, i have yet to find a way to do that.
