DX to Ex conversion Please Help
Old Jan 15, 2014
OutlawJDM's Avatar
OutlawJDM is an unknown quantity at this point
hello everyone i am truing to get to the bottom of something. i have an auto 2004 civic 4 door dx. it recently blew the bottom end and my girl bought me a jam d17a vtec. my question is i know a vafc2 can just be wired but so many people say to follow H8a diagram and some say don't use that use the h7a one? would it be easier to just use the 04 honda civic ex harness i have and edu and just get a key made at honda for 50 bucks? would i need anything else to make it run? Please help new to the site but not new to the game. thanks
Old Jan 15, 2014
Re: DX to Ex conversion Please Help
if the harness and ECU are for auto, *possibly*?
not sure if there would be any of the other stuff that might require work, depending on what your car have and what the other car had?
Old Jan 15, 2014
I can't answer your questions....There are probably several different ways you could go with it.
I can tell you that if you decide to use a stock EX PCM in a stock configuration, you would need to get the EX PCM programmed to the immobilizer unit already in your car so it will let the engine run. Use your original keys and ignition.
Just getting a new key by itself won't do you any good at all.
The dealer I work for charges half the price of other dealers nearby for programming keys and stuff.
Old Jan 15, 2014
oh, yeah, i forgot to mention the immobilizer
Old Jan 16, 2014
OutlawJDM's Avatar
well the swap is in the car with the dx harness and edu and the car runs idles fine just don't wanna try driving it without the vtec. thats why i so lost i don't know what is the safest way to get it to run right and not worrie about it
Old Jan 16, 2014
Drive it, you are done.
The engine doesn't care if the VTEC stuff is connected or not. That can't hurt it.
You don't have anything connected to the VTEC stuff, it will act like a normal non-VTEC engine. That's all it is now.
YMMV
Is there anything else you didn't have wires for? Everything else is hooked up?
Old Jan 16, 2014
OutlawJDM's Avatar
no took out the old motor swapped moved over the tranny to the jdm d17a harness on my car had all the same plugs didn't even move anything over. the only thing that was different was the jam alt and it cause the ground and the plug were reversed but still hooked it up. left the dx exhaust on no check engine light. have a battery light on and an airbag light and that it. the radio is weird also it will work on acc but not when the car runs. but it idles good revs good no vtec sensor is hooked up so it got me i didn't think it was gonna be that easy. lol
BJB
Sep 14, 2015 11:16 PM
tomas6791
Sep 11, 2015 06:47 PM
Pier7866
Sep 6, 2015 06:54 PM
Broadbeb
May 14, 2015 09:49 PM
AceKicker
Jun 15, 2002 01:01 AM
