DIY: No More Trunk Rattle!
Old Dec 15, 2001
OPGForce's Avatar
OPGForce is an unknown quantity at this point
1. On the inside part of the trunk lid, there are rubber stoppers on each side. Losen those a little by turning "counter-clock wise" (till you can see 1 to 2 rings). Then test to see if the trunk will close properly after.
2. Move the trunk lock latch down further by removing the plastic cover around the latch by pulling it out(might take a little more muscle compared to other panels). Using a 10mm socket wrench, losen the 2 bolts a little, then move the latch down all the way (line it up with the last tick as shown it the pic) and tighten the bolts. Test to see if trunk will close before putting the plastic cover back on.
Now your trunk lid is super air tight.
By the way, I installed to rolls of "Dynomat Extreme" on the trunk lid, so that probably helps a little. Also, I am running 2 12" Alpine Type-R's subs, and each sub has a V12 MRV-T707 amp powering it.
Hope this helps u guys out!
P.S ---> This is how I stopped my rear deck from rattling. (Shoved to "2 thick old socks in between the "third brake light" and "rear deck".
Old Dec 15, 2001
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Thanks man, this sounds cool, I am sooooo going to be trying this when I get home, my trunk rattles like a son of a *itch, with my subs.
Thanks again man.
Crashoveride
Old Dec 15, 2001
BumpinCivic2k1's Avatar
BumpinCivic2k1 is an unknown quantity at this point
yeah my trunk sounds so ghetto...thanks man
Old Dec 15, 2001
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Where did you guys mount the subs? I'm looking for a place where they won't take up too much room. I looked at Allman's idea, but he says it won't work with 12ers. He said 10s are pushing it. I appreciate your help.
Old Dec 15, 2001
AFlyer's Avatar
AFlyer is an unknown quantity at this point
i love the idea that derek did, moving the spare tire to under the car and putting the subs flush in the false floor of your trunk. i hope to do that someday, when i have the time and money.
Old Dec 15, 2001
autobots's Avatar
autobots is an unknown quantity at this point
a guy on ebay sells sub holders to go on each side of the trunk. also if u want something like derek they have some on sounddomain.com
Old Dec 15, 2001
bluecoupe's Avatar
bluecoupe is an unknown quantity at this point
nice tip.
do you have / can you post a picture of how you have the dynamat installed?
Old Dec 16, 2001
OPGForce's Avatar
<< nice tip.
I don't have any pics. If you plan on doing the DIY, I suggest doing the DIY first before going out and buying "Dynomat Extreme" to see if the rattling stops. To install dynomat extreme, just add 1 big piece to the underside of the top of the trunk lid and another piece to the part behind the license plate.
Old Dec 16, 2001
2k2civic's Avatar
Ok, that sounds great and all, but my 2002 LX coupe doesn't seem to want to slide up or down, it just has one hole where it is supposed to bolt on, not a sliding track like I have seen on older cars.
Old Dec 16, 2001
OPGForce's Avatar
<< Ok, that sounds great and all, but my 2002 LX coupe doesn't seem to want to slide up or down, it just has one hole where it is supposed to bolt on, not a sliding track like I have seen on older cars. >>
Strange? I only moved my latch about 1/3" down, and this was as far it would go. Also, my car is an EX, but the trunks should be the same for all coupe models. Go take another look a you trunk latch, and if that dosen't work out, try playing around with "Step 1" of the DIY. This gets rid of a fair bit of rattle.
Old Dec 17, 2001
2k2civic's Avatar
I don't see any room for moving my latch at all. If someone has already done this and can take a picture for me, I would really appreciate it.
Old Dec 17, 2001
2k2civic's Avatar
Wait a second? Are we talk about the latch assembly on the trunk lid or the latch thats on the trunk?
Old Dec 17, 2001
OPGForce's Avatar
the latch on the trunk.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 18, 2001
Dr5D's Avatar
My trunk dosent rattle, I guess because I don't have subs... yet. But I would like to prepare and tighten the trunk anyways, it there a way I can make sure I did it correctly?
Old Dec 18, 2001
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Thanks, I'll try it when my car gets back from the shop. Hope it works because that rattling sounds so cheap, totally messes up the sweet bass from the outside. sounds like my speakers are blown, or my car is a rattly old POS.
Old Feb 4, 2002
CityGuySam's Avatar
CityGuySam is an unknown quantity at this point
i did all that and it still rattles
Old Feb 7, 2002
TeamStylesRacing's Avatar
TeamStylesRacing is an unknown quantity at this point
My trunk seems to be made of tin can, it rattles like biznatch. gonna try to do it this weekend.
Old Feb 8, 2002
AJ's Avatar
AJ
AJ is an unknown quantity at this point
My rattle comes mostly from behind the plate. Would that help it? I am hitting very hard back there so it may just be screwed 2 15's.
Old Feb 8, 2002
PerfectD3's Avatar
PerfectD3 is an unknown quantity at this point
You can tighten it all the way down, thats what I did, for about a minute, cuz the trunk body panel, and the rear quarter panels no longer lined up!
Old Feb 8, 2002
nongv's Avatar
nongv is an unknown quantity at this point
pics?
Old Feb 9, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
does this work also on the LX-sedan
I think that pictures would be very helpful......
gonna be putting in 2 12's soon and dont want so much damn rattling.
Old Apr 12, 2002
MadMike's Avatar
MadMike is an unknown quantity at this point
I did it last night and had the same confusion you did.
The DIY is refering to the bottom latch above the rear bumper - not on the trunk lid it self.
You need a little muscle to take the black plastic covering off (approx 2 feet long).
I pryed my fingers under the top right corner and just pulled slowly but firmly and it came off.
Unscrew the two 10mm screws and move the latch down (It will be able slide about 1/2" up or down)
I found that if I had it all the way down my trunk couldn't close.
I set it at about 4mm before maximum slide down.
Getting my subs next week so let's see if it works.
Old Apr 12, 2002
HeRbaLuS's Avatar
hmmmm ok now its all clear......gonna try it
Old Jun 17, 2002
2Furious's Avatar
2Furious is an unknown quantity at this point
ALEXLX first told me about how to stop the rattling by doing this. It works. Thanks! Make sure you twist the stoppers the same amount though.
Old Jun 18, 2002
WhiteRabbit's Avatar
nothing kills trunk rattle better than expanding foam
Old Jun 18, 2002
NukeSilo's Avatar
NukeSilo is an unknown quantity at this point
where do you spray that without it looking bad?
Old Jul 2, 2002
skitzo's Avatar
skitzo is an unknown quantity at this point
Did this today on my 02... If you look real close at the latch and the body you will see alignment marks (3 of them) mine was on the top one when i started i could push the trunk and it had some play, i moved it to the bottom mark and the latch didnt catch. I ended up moving it to the middle mark and it closed tightly and there was no more play.
Old Jul 10, 2002
dickdaney's Avatar
dickdaney is an unknown quantity at this point
I'm going to ty that too. my trunk rattles like an s.o.b. I have dynamat all over the ish, but when the bass goes up the rattles get annoying if I'm standing outside of the car
Old Jul 10, 2002
dickdaney's Avatar
I did what you suggested. All I had to do was loosen those rubber things about two or three rings and no more trunk rattle. It all depends on where people are having problems. For me It was with the trunk rattling against the bumper. I already have a ish load of dynamat xtream and original. For the people that don't they might want to go ahead and get some. The choices are between dynamat raamat and b-quite. IT's all the same ish so it doesn't matter
Old Jul 10, 2002
mohawkboom's Avatar
That stops the trunk from rattling. Now for the rear deck [IMG]i/expressions/face-icon-small-smile.gif[/IMG].. Remove the rear deck. Add 1 sheet of 1/4" FOam padding. Cut holes as needed for the clips. put rear deck back on.....Done. If anyone ever has any questions on deadenign thier car..PM Me... I've spent the last 4 months making my car as dead as can be.
Cheers
Mohawk
