Help!
Old Feb 14, 2004
KeNsHiN's Avatar
LEVA
Unhappy Help!
ok so here is what happend........about two days ago i was trying to start my car and it wouldn't turn! after about four tries it worked but it only got worst........on my way home i parked in my drive way and chilled for a min(about 15 mins. watching a dvd w/ car off)......then my sister came home and i had to move, well when i went to start my car and it did the same thing but worst! after about six or seven tries (i thought i flooded the engine for sure) the car came on...........the next morning i go out to check my car b4 i take it to the bay and i raise my car and take it on a test drive with no issues. I went back home and started raising the rear and when i try to move the car it died! nothing! nothing! my lights work but nothing else not my dvd player or the screen and when i turn the key the lights just die then come back on! help i need my car!!!!!!!!!!!!
Old Feb 14, 2004
EM2191MW's Avatar
EM2191MW is an unknown quantity at this point
battery?
Gas?
what light come on when you try to start it?
if you see an engine light flashing, call your Service Department and ask them what how ever many flashes means, and tell them your trying to get your car there so they can check it out "wink".
good luck sorrry to hear thats happening.
Old Feb 14, 2004
civicguy777's Avatar
civicguy777 is on a distinguished road
sounds like a battery issue...
Old Feb 14, 2004
and if your battery is ok then have yur alternator checked out
Old Feb 14, 2004
DizWikedCivic's Avatar
if not a battery issue it your electrical system, meaning u might need a new alternator
Old Feb 14, 2004
aZnVoYCe's Avatar
Yeah, what they said. Have you tried jump starting your car?
Old Feb 14, 2004
KeNsHiN's Avatar
LEVA
^why i have with a car and a "box" jumper. i also swapped batts with my my girl and samething........
Old Feb 14, 2004
how long did you drive arround or have stuff running with her batt. you need to check your alternator then, cuz even on a brand new batt, if your alt is not working it will drain hella fast, how much stuff you running in your car (ice)you may have over worked the alt.
Old Feb 14, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
yea im thinkin the alternator is dead or starter....i think it mostly likely gonna be the alternator cuz it seems like its not charging back to ur battery
Old Feb 15, 2004
AntDeezy's Avatar
prolly this ^^^ i went thru this with another car, .... replaced the starter and the alt. and worked fine ....
BTW i just bought both, you may not need to ...
Old Feb 19, 2004
KeNsHiN's Avatar
LEVA
i got it! my damn alarm was just trippin and it killed my engine! i think i still have a warranty from cliff. lol well koo and thanks
Old Feb 21, 2004
aZnVoYCe's Avatar
Nyce find, guess none of the advices helped huh? Hah.
Old Feb 21, 2004
INSTALL is everything, your install is shitty, your **** going to function shitty
Old Feb 23, 2004
AntDeezy's Avatar
I agree with the above statment ....
Old Feb 25, 2004
S2KREY's Avatar
formerly 2k1CivicRacer
S2KREY is on a distinguished road
same here...shiit shiiit shiitttyyyy!
