wtb 04-05 manual tranny possible 01-03 with low miles
Old May 17, 2007
familycar's Avatar
just like the title says, my tranny is popping out of 3rd and starting to do it in 2nd. i know in 04-05 they fixed the problems that the 01-03's had that is why those years are my prefference
Old May 17, 2007
spoonEM's Avatar
omgwtfbbq mod.
Re: wtb 04-05 manual tranny possible 01-03 with low miles
Bob (dopes6070) has one from an 01 thats rebuilt. I can even put it in for you if you want. haha
Old May 17, 2007
ragingSPAM's Avatar
I just burnt my tongue
usually popping out of gears means that there isnt enough oil in it...check the oil level and go to honda get some of the synthetic fluid it requires not conventional motor oil and try it...but yes i do believe that the 01-03 tranny's had that as a minor problem
Old May 18, 2007
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
I do have that manual trans still... it’s a 01 but it shifts better then my 02 MT ever did... For the rebuild I'm just replacing the input shaft bearing and checking all the specs... the gears synchronizers and shafts have no wear even after 120k. Maybe we could do a core exchange?
A manual trans popping out of gear is usually caused by the synchronizers or the shafts being out of alignment not low oil. A grind or notch in the shift can be caused by low oil though.
CarStuff
Dec 6, 2020 12:52 PM
MajTom
Jun 2, 2015 11:48 AM
lildoo
May 9, 2015 09:44 AM
dosmastr
May 5, 2015 12:19 PM
bsmiley
Apr 27, 2015 01:27 PM
