camber problem
Old Jun 23, 2006
lilaznboi2486's Avatar
lilaznboi2486 is an unknown quantity at this point
camber problem
hey guys..i just saw the other day that my rear right tire cambers both on the inside and out.. there is severe camber ware on both the inside and outside of the tire...how is that possible?...i do have a rear camber kit on..however im unsure of how i should adjust it?..becuhz of the fact taht if i adjust it one way..ill even more severe camber ware on one side of the tire..and if i adjust it the other way..i get camber ware on tat side...can someone help me?..
Old Jun 23, 2006
Nodnero's Avatar
If you have extreme wear on the inner/outer sides of your tires, you could start by putting more air in the tires as it could be due to underinflation. Or, when the tires were rotated they ended up on the other side of the car.
Old Jun 23, 2006
hmm.....ill try to rotate tires again..and put a tire without camber ware on my rear right..and put air in it...i hope that tire doesnt get camber wear too
Old Jun 24, 2006
SEVYN's Avatar
SEVYN is an unknown quantity at this point
SPC kit?
Old Jun 24, 2006
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
take your car somewhere and get the camber ajusted. Computers are better than the human eye. your camber might be off. Just cause you cant see it doesn't mean its ajusted right
bo_red
Apr 23, 2015 10:09 PM
ayzan
17
Jun 30, 2002 12:36 PM
ZITRO
Feb 7, 2002 12:12 AM
ernhole1
Dec 6, 2001 12:05 PM
RickyRocket
Nov 30, 2001 10:14 AM
