14.908 @ 94.707
Old Mar 5, 2006
NoMoreHonda's Avatar
Go Dodgers
NoMoreHonda is an unknown quantity at this point
14.908 @ 94.707
I went to speedworld out here in Arizona to run my car for the first time with the k20a swap. First of all the car is untuned. I ran the 14.9 @ 94.7 mph.. I'm sure once I get stronger axles and tuned I will run a lot better times. here is the brake down of what I did:
60' - 2.334
330' - 6.390
1/8 - 9.690
1000' - 12.442
1/4 - 14.908
Old Mar 5, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
what was the temperature?
I just did a quick search and the elevation at speedworld is 1350 ft... so a sea-level corrected time would be about 14.7 ;P
aren't you in socal?
Old Mar 5, 2006
Go Dodgers
im moving back 2 cali next month... right now im in arizona
Old Mar 6, 2006
civicvtec1ps's Avatar
Search and Learn
Not a bad time, you know you can do alot better.
Motor
Old Mar 6, 2006
iamboo's Avatar
Retired - SoCal FI Mod
you must have been spinning... 2.3 60' is a decent time but there is def room for improvement.. what was your trap speed ?
Old Mar 6, 2006
Go Dodgers
It was wierd.. I trapped at 94.707 when I got my 14.9, but when I ran my 15.1 I trapped at 95.6
Old Mar 6, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
uh... wow. how big are your rims?
did you lower tire pressure at all?
Old Mar 6, 2006
HondaLuver's Avatar
Its a celebration bitches!
what tires are you using?
Old Mar 6, 2006
Go Dodgers
what tires are you using? Nitto Neo Gen
how big are your rims? 17's
did you lower tire pressure at all? Yes to 24 psi
Old Mar 7, 2006
PunkingCivic's Avatar
I need TP for my bunghole
Right on Phins!
Old Mar 7, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Hell Ya GOOD TIMES (literally)
