Need help on why srs signal is displaying on my dash
Old Jan 15, 2006
Mrs014dr's Avatar
Mrs014dr is an unknown quantity at this point
So I put my racing seats in today and I made the part where the seatbelt clicks in at is stiff on the seat. I click in the attachment of the seatbelt under the seat but still for some reason srs signal is displaying on my dash. Is that normal when you replace the seats? Need help tryin to fix the small issue please.
Old Jan 15, 2006
monkeyness's Avatar
I like to stuff a l0t 0f c00kies int0 my m0uth!
monkeyness is on a distinguished road
there is a fix, search girl!
using a little wire and loop it, very easy...
Old Jan 15, 2006
Mrs014dr's Avatar
Oh ok I can try that I guess
Old Jan 15, 2006
southpasdena's Avatar
Super Member
southpasdena is an unknown quantity at this point
yea you need this part that cost like $2-3 and some wire and there is a series times where you insert and remove it from something inside the fuse box. I forgot, if you actually figure it out let me know bcuz mine has been on for 6 months
Old Jan 15, 2006
spoonEM's Avatar
omgwtfbbq mod.
theres a DIY in the DIY section. You probably turned on the ignition without your airbags all plugged in....or else its still not plugged in. Make sure everythings connected otherwise it wont go off with the DIY.
Old Jan 15, 2006
jkim1978's Avatar
jkim1978 is an unknown quantity at this point
there might be something wrong with your ecu... i tried to diy with the paper clip like 10 times... and after like 5 min the light would come back on... so i had to take mine to the dealer.. and they said something was wrong with my ecu or something...
Old Jan 18, 2006
Mrs014dr's Avatar
Well i am going to take my car to a import shop tomorrow and see if they can tell i might try unplugging my battery for awhile and see if that works
Old Jan 19, 2006
Super Member
wont work, it has to be reset
