Anyone need something built/installed?
Old Jan 12, 2005
turboengnr's Avatar
DONT PANIC
I can build just about anything, and can install just about anything. I can do stereos, turbo systems, nitrous, emanages, SAFC's, VAFC's, anything.
If you want a custom turbo setup, i can help ya out on that for cheaper than any shop, And have the same quality. If you have your own turbo, a little over $1300 will get your car up and running with everything but an intercooler (this includes fuel system)
So if anyone needs something installed/built, PM me. Ive been outta work for about a month now and need some side jobs to keep me busy.
Old Jan 12, 2005
turboengnr's Avatar
DONT PANIC
I Am Bored Outta My Freakin Mind!!!!
Old Jan 12, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
you around san diego? lol
Old Jan 12, 2005
PunkingCivic's Avatar
I need TP for my bunghole
fill out your profile if you board.
People would like see to where the hell you are located.
and so.
Old Jan 12, 2005
turboengnr's Avatar
DONT PANIC
ah, sorry. I am in palmdale.
Old Jan 12, 2005
turboengnr's Avatar
DONT PANIC
for about $30 i will build & install a short shifter adaptor.
it works really well on my car
Old Jan 12, 2005
VTECTypeR's Avatar
A full turbo kit for a automatic. How much are we talking installed and everything
Old Jan 12, 2005
Kable's Avatar
Formerly known as Veritas
Kable has a spectacular aura aboutKable has a spectacular aura about
you know vws? because I have a 03 gti 1.8t and I've been wanting a turbo timer installed for the longest time but just don't have the time for it and know how to do it, let me know if you know how to install one to make it work with my oem alarm.
Old Jan 12, 2005
iceman's Avatar
--< GripSpeed Member >--
u know how to work on a vg30de (300zx)...and how to tune it if i had the Safc
Old Jan 13, 2005
turboengnr's Avatar
DONT PANIC
vtectyper.... If you bring me the turbo (just the turbo itself), its $1300 installed with no intercooler. The only reason i cant do an intercooler, is because i have no way of welding aluminum. If you want an intercooler, they are about $300 on ebay, and probably another $200 for the extra piping.
Veritas.... I have installed many turbo timers. The only one i have gotten to work with the factory alarm was the civics.
Iceman.... If i still had my wideband, i could tune the crap out of it. We could try to tune it with the safc and no wideband, but without knowing where we are, it could prove to be dangerous.
Old Jan 14, 2005
VTECTypeR's Avatar
So youll install a turbo with no intercooler. where would i go for the intercooler and the extra piping?
Old Jan 14, 2005
turboengnr's Avatar
DONT PANIC
if you can get an intercooler (off ebay or from a friend) i can install it. Its about another $300 in piping.
So you bring me the turbo, it is $1300 for everything else. Bring me the Turbo and intercooler, its $1600 for everything else.
Old Jan 15, 2005
sb143hd's Avatar
sb143hd is an unknown quantity at this point
how are you with tunning/ turbo rebuild, i have a used SF turbo kit, need to rebuild the turbo to make it quit smoking, and need to have electronics hooked up and tuned! how much, and do you know a shop with a dyno, I'd like to tune it on a dyno! thanx!
Old Jan 15, 2005
J_J's Avatar
J_J
J_J should not be trustedJ_J should not be trustedJ_J should not be trustedJ_J should not be trustedJ_J should not be trustedJ_J should not be trustedJ_J should not be trustedJ_J should not be trustedJ_J should not be trustedJ_J should not be trustedJ_J should not be trusted
How much to install a new radiator support for a 03 Civic?
Old Jan 16, 2005
turboengnr's Avatar
DONT PANIC
actually guys, i just started a new job in San Bernadino. So i commute 70+ miles every day.
I cant rebuild turbos, because they need to be assembled by someone who can balance the shaft.
Isnt the radiator support welded in?
Old Jan 16, 2005
J_J's Avatar
J_J
I don't think so. It looks like this:
Old Jan 16, 2005
kimchi29's Avatar
soooon to be psshh
kimchi29 is an unknown quantity at this point
hey wussup, do you know how to do retros for hids?
