i got a problem
Old Feb 1, 2004
amhtown01's Avatar
i got a problem
basically, i hit a pot hole and my radio turned off (aftermarket) yday. today i noticed that my AC button doesn't even turn on green. i check to see if the fuse for both the radio and the AC are blown but they're not. Confused i close everything and push the alarm button(stock) and it doesn't work!! . Anyone out there that can help?
Old Feb 1, 2004
HondaLuver's Avatar
Its a celebration bitches!
where exactly did you hit the pole? cause it could have shorted out something like ur ac pump or something....blah...
Old Feb 1, 2004
7thGenerasianCivic's Avatar
It is possible that you hit it so hard that you loosened the wirings.
Old Feb 1, 2004
amhtown01's Avatar
i hit it with the front right tire.
Old Feb 1, 2004
^ wow that's the side where all the wiring are. hmm... try checking all the wiring from that side and make sure they're nice tight and comfy. Maybe just wiggle the wires around and hope that will fix it.
Old Feb 1, 2004
Civicly02's Avatar
there might be a fuse that your missing. It is underneath the hood I forgot which one it is but that is the same thing that happen to me also
Old Feb 1, 2004
amhtown01's Avatar
ok, things seem to be going ok. checked the fuses they are not blown. but now my door locks wont work and the alarm still isn't working. The radio is in the same non working condition, but I do have AC now.
Oh yiah, the power doorlocks it didn't work when i was home, but when i went out it worked. When i got back in my car to go home they stopped working.
Old Feb 2, 2004
XtremeJM's Avatar
man you got some major issues, is your car still under warranty?
Old Feb 2, 2004
amhtown01's Avatar
my car is still under warranty. but i'm pretty sure they'll say something since my car is dropped.
Old Feb 2, 2004
Nodnero's Avatar
Dude, Abe just take it to Hardin. They always took care of us even tho ours cars had some work done to it. Im sure they will tell you what it is, just say that you dont want them to fix it if it isnt warranty.
Old Feb 2, 2004
XtremeJM's Avatar
see chase knows whats up
Old Feb 2, 2004
amhtown01's Avatar
i guess i'll go on wednesday.
Old Feb 2, 2004
hothondacivic02's Avatar
hothondacivic02 is an unknown quantity at this point
Check all ground wires if you loosened a ground it could be grounding out somewhere else and causing your electronics not to work since it goes on randomyl it seems you have power i would check all grounds
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
