FS: My system, checking interest!!!
Old Sep 13, 2003
7thgencivicdriver's Avatar
7thgencivicdriver is an unknown quantity at this point
Cool FS: My system, checking interest!!!
What's up ya'll. I'm thinkinhg of upgrading my system so I want to see if anybody is interested in buying the one I have already. I consider this a good starter system and I really like the way it sounds but I NEED MORE! Anyways this is what's up for grabs;
2- Infinity Reference 12" subs. 300watts RMS 1200watts peak each.
1- Subwoffer box- I don't know the thickness but it is made out of MDF and I bought for $50
1- Performance Teknique 500 watt amp
All the wiring that's hooked up to it.
Everything is only 6 months old and I didn't even bump it that hard (only when parked) because the car rattles so much.
Anyways, I'm asking $250 obo for everything the subs, amp, box and cables.
I only have one of the subs boxes (supplied if requested) and the amp box but cant seem to find the paper work for amp. Anyways take advantage its a good system and am willing to keep it but an offer was given to me for a more powerfull system and I need to get rid of mine so that I can dive into the new one.
Thanks for looking.
Oh yeah, and I'm going to be in the Riverside area alot after sept 25 when classes start, so I'm willing to meet anyone half way.
Old Sep 13, 2003
DaZeD's Avatar
Don't Hate. Just Envy.
im interested in u can get pics and possibly specs
Old Sep 13, 2003
Specs on subs (from crutchfield where purchased):
Key Features:
power range 50-300 watts RMS each
peak power 1,200 watts
frequency response 20-800 Hz
sensitivity 92 dB
top mount depth: 6-1/8"
sealed box volume: 1.25 cu. ft.
ported box volume: 2.0 cu. ft.
And On amp:
Maximum Output Power @ 2 Ohms: 250W x 2CH Power Output @ 2 Ohms: 120W x 2CH Power Output @ 4 Ohms: 100W x 2CH Power Output Bridged: 240W x 1CH THD: 0.05% Signal to Noise Ratio: >95dB Frequency Response: 15Hz to 40kHz Crossover: Separates High-pass: 50Hz to 1kHz Variable Low-pass: 30Hz to 500Hz Variable Slope: 24dB Octave Subsonic Filter: 10Hz to 100Hz Variable Bass Boost: 0 dB to 18dB Variable Input Sensitivity: 200mV to 6V Variable Low level Input Impedance: 47K Ohm Damping Factor: 180 into 4 Ohm Channel Separation: >80dB High & Low Level Input through RCA Double Sided PCS Dual Protection (Thermal & Short Circuit) RCA Line Out Power & Diagnostic LED Indicator 2 Ohm Stable Soft Delayed Power On Tri-Mode Capability Power Supply Consumption (Bridged RMS): 27A Fuse Rating: 15Ax2 Dimension (WxHxL): 9.96" x 2.12" x 11.96
Old Sep 13, 2003
Oh yeah, sorry I have no pics, but
linky for amp http://www.ultimate-sounds.com/icbm/icbm771.htm
and for subs http://www.crutchfield.com/S-dL6iuqk...asp?i=1081220W
Old Sep 13, 2003
Check it, I bought all these things retail
Subs: $100 piece
Amp : $175 (less than retail)
Box: $50
Wires: Came w/ install so say $20.
Over $400 spent but desperate to sell.
This is a complete system nothing more to buy!!! (Well except headunit nd some components)
Old Sep 14, 2003
CivicHX01's Avatar
yay... a fellow 7thgener at ucr... do you dorm it? i stayed at east lothian last year... well anyways hopefully i'll see ya around
Old Sep 14, 2003
Nah, I dont dorm, I commute. I'll be entering my fourth year this fall!
Old Sep 14, 2003
Nodnero's Avatar
Subs: $100 piece
Box: $50
Im not mocking, flaming or anything like that, but I like his last sentence.
Old Sep 16, 2003
bump, for those that haven't seen
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
