My new whip (as Dallis put it)
Old Jun 10, 2006
AZ2K1Civic's Avatar
Everyone meet my new patrol vehicle
2006 Dodge Charger Police Package Information
# Dodge puts 340 horses under good guys' hoods
# Dodge Charger joins Dodge Magnum to make modern muscle available for street patrol
# Superior rear-wheel-drive performance and handling characteristics designed to perform and protect
Auburn Hills, Mich. - Dodge charges into the police car market this fall with the all-new 2006 Dodge Charger police vehicle, offering law enforcement agencies a four-door sedan with all the power, handling and functionality they require to effectively patrol the streets.
"With rear-wheel drive and available HEMIŽ power at the pavement, the Dodge Charger provides optimum police car pursuit performance," said Darryl Jackson, Vice President - Dodge Marketing, Chrysler Group. "Dodge has a strong police heritage and is proud to offer vehicles armed with modern muscle and cutting-edge technology."
The 2006 Dodge Charger police vehicle will join the previously announced Dodge Magnum police vehicle to round out Dodge's growing fleet of bold, powerful and capable vehicles for law enforcement agencies.
"We listened to what law enforcement officers asked for and paid attention to the details that are important to them," said Ray Fisher, Vice President - Sales, Service and Parts Operations, Chrysler Group. "By integrating features and functionality into the original design of the Dodge Charger, we can give our police customers an affordable, capable vehicle with industry-leading innovations."
For the ultimate in pursuit power, the Dodge Charger police vehicle will be available with a 5.7-liter HEMI V-8 engine that produces 340 horsepower at 5000 rpm and 390 lb.-ft. of torque at 4000 rpm. The V-8 HEMI engine features Chrysler Group's Multi-displacement System (MDS), which seamlessly alternates between smooth, high fuel economy four-cylinder mode when less power is needed and V-8 mode when more power is required. Fuel efficiency improves by up to 20 percent with MDS, but not at the expense of performance. Dodge Charger police vehicles equipped with HEMI engines will be able to go from zero to 60 mph in just 6.0 seconds.
The 2006 Dodge Charger police car also will be available with a powerful, 3.5-liter High Output V-6 engine that provides 250 horsepower at 6400 rpm and 250 lb.-ft. of torque at 3800 rpm, offering an outstanding blend of performance and fuel economy.
A fully electronic five-speed automatic transmission with an Electronically Modulated Converter Clutch (EMCC) offers improved shift feel to match a variety of driving styles, situations and road conditions. This transmission is standard on all Dodge Charger police cars. Heavy-duty brakes and linings, also standard on Charger police vehicles, provide secure and stable deceleration and braking capability.
In addition, Dodge Charger police vehicles will include an Electronic Stability Program (ESP) with Emergency Brake Assist, All-speed Traction Control and four-wheel Anti-lock Brake System (ABS). Combined, these features will provide balance and control for officers in a variety of surface and weather conditions.
# ESP enhances driver control and helps maintain directional stability in turns, even on uneven surfaces, patchy snow, ice or gravel. If there is a discernible difference between what the driver asks through the steering and the vehicle's path, ESP applies selective braking and throttle control to put the car back onto the driver's intended path
# Emergency Brake Assist detects when maximum braking is required through sensing the rate of brake application. By applying full brake pressure to all four brakes, this system improves stopping distance
# All-speed Traction Control enhances mobility and prevents wheel slip when accelerating on slippery surfaces. It also provides a measure of directional stability control and helps keep the car on its intended course. The system works by braking the slipping wheel in low-traction situations. However, it also can adjust the throttle control, making the vehicle less reliant on brake applications alone
# ABS keeps the vehicle straight and retains steering capability while braking on slippery surfaces by preventing wheel lock-up
Both passive and active safety features also are incorporated in the new Dodge Charger police vehicles. These include: advanced multistage driver and front passenger air bags, a front passenger Occupant Classification System (OCS) for controlled airbag deployment, constant force seat belt retractors, pretensioners, an energy-absorbing steering column, optional side-curtain airbags and a tire pressure monitoring system to alert officers of low tire pressure.
Preliminary Standard Features Standard features on the 2006 Dodge Charger police vehicle will include the following items of particular importance to law enforcement customers:
# 100-amp battery power feed in trunk
# 160-amp high-output alternator
# 160-mph calibrated speedometer
# 800CCA heavy-duty battery
# cloth front bucket seats with manual lumbar and rear fixed bench seat
# column shifter
# easy path wiring grommet between underhood and passenger compartment
# emergency rear-door-lock override
# external oil coolers
# four-wheel independent performance suspension
# heavy-duty brakes and linings
# integrated engine hour meter
# P225/60R 18 V-rated all-season performance tires and 18-inch steel wheels
# performance-tuned steering
# police equipment interface module
# police equipment mounting bracket
# rear door locks and rear window switches inoperable from the rear seats
# severe-duty cooling system
# software-controlled alternating head- and taillamps
# special electrical wiring for police market applications
# speed control
# stealth mode switch for interior lighting
Additional standard features and optional equipment are available on the Dodge Charger police vehicle to provide law enforcement customers an affordable vehicle with industry- leading innovations that make upfitting the vehicle faster and safer.
Old Jun 10, 2006
alex053's Avatar
i just saw one of those the other morning....they look pretty good.
Old Jun 11, 2006
EnProceso's Avatar
dang, thats pretty rad.i'm off to the academy in august, hope when i get out, they gimme a car like that!
Old Jun 12, 2006
Rufus's Avatar
I feel another ride-a-long coming on...
can I sit in the front this time?
Old Jun 12, 2006
shifthis's Avatar
shifthis will become famous soon enoughshifthis will become famous soon enough
That is sweet.
Old Jun 12, 2006
oi2325's Avatar
oi2325 is an unknown quantity at this point
i am so happy we dont have those down here, were to cheap...i hope
Old Jun 12, 2006
topnotch7gen's Avatar
JDM-Jonathan David Martin- I own everybody
topnotch7gen is on a distinguished road
Damn, no more running from cops j/k That's craaaaazy, a charger?!?!
Old Jun 13, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Cool!
Old Jun 15, 2006
ponyman's Avatar
ponyman is on a distinguished road
340hp and 390ft-lbs aren't bad numbers...but 0-60 in 6.0 seconds...man what does that thing way 12,000lbs...If it weren't for the fact tha you guys cheat and use radios and spike strips and helicopters I would be breathing a sigh of relief knowing that I could outrun you in a heartbeat....damn technology.....
Looks pretty bad *** for a cop car though....
Make sure not to get any donought juice all over that nice interior...j/k..please don't arrest, taser, or shoot me...I only kiddd
Old Jun 16, 2006
AZ2K1Civic's Avatar
Remember its got a cage in the middle, lights, push bar, steel wheels, extra power sources, super cooling system, radios, gun racks, etc...thats not including all the gear I put in the trunk everyday.
140 mph last week and still had room under the pedal...
Old Jun 19, 2006
ponyman's Avatar
You know there is a joke right there (something involving donuts and a place to store them) that i could make, but I don't want to get arrested, tasered, or shot.
Second to the Fox body persuit Mustangs that they used to make and I several Highway Patrols used I definitely think the Chargers are probably the coolest cop cars. Camaro pursuit cop cars == POS crap....
BTW, I thought you were DPS not MCSO????
Old Jun 19, 2006
alex053's Avatar
how long did it take you to block all id factors out of that pic?
Old Jun 20, 2006
Rufus's Avatar
haha MSPaint owns joo
Old Jun 25, 2006
AZ2K1Civic's Avatar
Negative
bout 5 seconds
true
Old Jun 25, 2006
ponyman's Avatar
Negative
Do you ever get the urge at work when you are to respone to something with Negative, to instead say. Negative Ghostrider, the pattern is full? Because I think that would be really funny.
Old Jun 25, 2006
alex053's Avatar
Old Jun 29, 2006
AZ2K1Civic's Avatar
Negative
Old Jul 4, 2006
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Yeah, I could see where you guys need those in Phoenix but here in Oregon they have a few now.. This place is so unlikely to see anything REALLY fast... HAHA what a joke. Keep them in big portland when something actually happens LOL Haven't seen the Mustang GT yet either around here but just a matter of time.
Jeffdp
Aug 5, 2015 11:38 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
wholt0
Transmission
Jun 11, 2015 11:15 PM
ashleymmackey
Apr 18, 2015 09:48 PM
DaddyFatSacks
Bolt-on Engine Performance
Dec 7, 2001 08:22 PM
