Lowering Issue...O.o
Old Apr 24, 2006
EXSilverFour's Avatar
EXSilverFour is an unknown quantity at this point
Alrighty I gots one for you. The shop at Earnhardt Nissan lowered my car for me (actually a few buddies of mine that work in the shop). It was done very well except for one thing. Now that I drive I get a slight clunking on the passanger side of the vehicle. I checked everything for tightness and found nothing wrong. Could this be the result of a misalignment? It's getting an alignment this week..I checked CV shafts and boots as well. No riped boots no spilled grease...any clues?
Old Apr 25, 2006
shifthis's Avatar
shifthis will become famous soon enoughshifthis will become famous soon enough
Is it a constant clunking or just a every once in a while you here a clunk. Is it when you are driving straight or only when you turn a certain direction.
Old Apr 25, 2006
2K1Civic17"Gabe's Avatar
its normal for clunking on lowered cars, when turning at least. not when driving straight. You could put a coil wrap of some sort on the springs to help out.
Old Apr 25, 2006
FALKEN's Avatar
Civicforums Junkie
Originally Posted by 2K1Civic17"Gabe
its normal for lowered cars
no its not
you could, but thats not always the problem...usually its from a poor install job.
Before you disassemble the strut, you need to mark the top and bottom to insure you line them up correctly when putting them back together. If you're working on a 2002+ model, the top mount should already be marked with an L or R (for left and right) and an arrow pointing in the direction it should be facing when it goes back on the car. If the top and bottom are not put together correctly the bolts will not line up in the strut tower (this is important). If the marks aren't there, just use some white-out or a marker. This insures that the springs are properly indexed when you reinstall them and that they seat properly into place against the rotation stop on the lower seat and the bearing lines up properly with the upper mount. In addition, if you properly install the spring and continue to experience a popping sensation, you need to inspect the bearings especially if you mess up and the bearings blow all over your garage floor. I recommend that once removed from the strut, you open up the bearing and add some lithium or graphite based lube into the bearing race then close the bearing back up. Before reinstalling, rotate the bearing with your hand to insure that it moves freely and the grease is worked around the *****. Then, re-install the upper seat and bearing assembly properly indexed and bolt the assembly together with the proper torque of 45 lb-ft. I understand this is typically impossible with the allen key, but if you get a crows-foot you will be able to properly torque the nut. If its too tight, it binds and pops. If its too loose, it wabbles and the races don't seat, the ***** are free to bounce and it pops.
Old Apr 26, 2006
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
my guess, its spring chatter aka coil slap, sounds like an std doesnt it? lol, if it is its just inherint of lowering springs, most of them do it, nuespeed in particular is notorious for it (yes i know my spelling sucks). its basically the "dead" coils on the upper wind, that slap together when expanded and compressing, if it is slap, then just look at the coils see about what size they are, 1" .5" etc, and go to home depot pepboys whatever, and get some black wire loom, then just wrap it around the dead coils should shut them up. At least it has for my cars when they had lowering springs....
my 2cents
Old Apr 26, 2006
bkerley's Avatar
bkerley is an unknown quantity at this point
Actually the only word that you spelled wrong is inherint
Old Apr 26, 2006
Rufus's Avatar
No he spelled neuspeed wrong too
Old Apr 26, 2006
FALKEN's Avatar
Civicforums Junkie
haha
Old Apr 28, 2006
JoeyOKC's Avatar
http://ackakaka.ytmnd.com
JoeyOKC is on a distinguished road
probably should have it aligned anyway....
I'd check tie rod boots if you hear it when you're turning. i had a bad clunk/rattle coming from mine that ended up being the nut at the top of the strut loose.
Old Apr 29, 2006
Rufus's Avatar
2 words Kanooter valve.
Old Apr 30, 2006
oi2325's Avatar
oi2325 is an unknown quantity at this point
I had the same issues. I had to tighten the top bolts that mounted the shock to the car, and the second time after i replaced the shox i had to tighten the screw at the base of the strut. I dont know about the 01-02, but for the 03-04 you need to cut the OEM strut in order to install new shox, did you cut to low if you also had to cut?
Old Apr 30, 2006
j.lu's Avatar
j.lu is an unknown quantity at this point
I have the same problem.I replaced everything.New Mount and bearing, new struts and the noise still there.Only when I driving straight I can hear the noise.I indexed 3 times.What now?
Old May 1, 2006
oi2325's Avatar
did you make sure that the new set up was installed the same as the old. all left side components need to stay on the left side, same for the right. if you think its just the springs poping, you might need to place a plastic tube around them. does it pop, clunk or slam when you drive-ie the sevarity of the noise. also, do you have the inserts or was it a direct install? if you had the inserts, was it a tight fit or loose
Old May 1, 2006
j.lu's Avatar
Is a direct install.I'll try the plastic tube to see what happen.
I just drove the car around the block and the noise is gone.
What I did?
Plastic tube around the springs rofl:
Old May 2, 2006
oi2325's Avatar
Nice, hope it doesn't bother you anymore
Old May 2, 2006
dragin's Avatar
only 2, not bad.
Old Jun 3, 2006
izmaxx's Avatar
izmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really nice
Just bought some Eibach Sportlines and it came with a plastic tube around the top few coils of the spring.
In the process of installing it now. Might be back in this thread in a few days if I started getting sounds.
Old Jun 3, 2006
oi2325's Avatar
Just make sure all the bolts a spec tightened and you shouldnt get any noise unless you didnt install the springs right
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bhollie
Sep 22, 2015 11:08 PM
