cleared lights
Old Apr 29, 2005
mp3allday's Avatar
mp3allday is an unknown quantity at this point
cleared lights
I know this is probably a stupid question but i was just wondering. I just cleared the headlights on my 03 ex and the parking and turn lights are a little bit dimmer then the main ones, so i was wondering if there are lights that i can buy so that they will kindof match.
Old Apr 29, 2005
uberjeff's Avatar
uberjeff is an unknown quantity at this point
Talk to Les (Tommy Tran). He can get you a hook up on some LED's that will look better.
Old Apr 30, 2005
FALKEN's Avatar
Civicforums Junkie
swap them out with amber (orange) bulbs
try www.autolumination.com
they sell bulbs that are chrome which blends in with the chrome housing and light up orange (or super-white) when turned on
Old Apr 30, 2005
mp3allday's Avatar
What number bulbs go in the Headlights and turn and parking
Old Apr 30, 2005
FALKEN's Avatar
Civicforums Junkie
headlight - H4
parking - 194
signal - 7443
Old Apr 30, 2005
mp3allday's Avatar
Do i have to have a yellow turn signal alot of people have been telling me its illegal to not have them
Old Apr 30, 2005
FALKEN's Avatar
Civicforums Junkie
heres a post from http://www.7thgencivic.com/forums/sh...d.php?t=122536 that will answer your question
28-931. Lamp colors
A. Front clearance lamps and those marker lamps and reflectors mounted on the front or on the side near the front of a vehicle shall display or reflect an amber color.
B. Rear clearance lamps and those marker lamps and reflectors mounted on the rear or on the sides near the rear of a vehicle shall display or reflect a red color.
C. All lighting devices and reflectors mounted on the rear of any vehicle shall display or reflect a red color, except that:
1. The stoplight or other signal device may be red, amber or yellow.
2. The light illuminating the license plate or the light emitted by a backup lamp shall be white.
28-941. Multiple beam road lighting equipment arrangement
Except as otherwise provided in this article, the head lamps, the auxiliary driving lamp or the auxiliary passing lamp or combinations of the head lamps, driving lamp or passing lamp on a motor vehicle other than a motor driven cycle shall be arranged so that selection may be made between distributions of light projected to different elevations, subject to the following requirements and limitations:
1. There shall be an uppermost distribution of light, or composite beam, so aimed and of sufficient intensity to reveal persons and vehicles at a distance of at least three hundred fifty feet ahead for all conditions of loading.
2. There shall be a lowermost distribution of light, or composite beam, so aimed and of sufficient intensity to reveal persons and vehicles at a distance of at least one hundred feet ahead, and under any condition of loading, none of the high intensity portion of the beam shall be directed to strike the eyes of an approaching driver.
3. A new motor vehicle, other than a motor driven cycle, that is registered in this state and that has multiple beam road lighting equipment shall be equipped with a beam indicator that is:
(a) Lighted when the uppermost distribution of light from the head lamps is in use and not otherwise lighted.
(b) Designed and located so that when lighted it is readily visible without glare to the driver of the vehicle.
4. A person shall not operate a motor vehicle with a colored transparent or translucent substance or material installed, affixed or applied on or in front of the head lamps, the auxiliary driving lamp or the auxiliary passing lamp or combinations of the head lamps, driving lamp or passing lamp that would obstruct, reduce or interfere with the visibility or effectiveness of the head lamps or that would change the color of light emitted. This paragraph does not prohibit the placement of clear transparent material mounted in front of the head lamps, fog lamps or auxiliary driving lamps.
28-947. Special restrictions on lamps
A. A person shall direct a lighted lamp or illuminating device on a motor vehicle, other than a head lamp, spot lamp, auxiliary lamp or flashing front direction signal, that projects a beam of light of an intensity greater than three hundred candlepower so that no part of the beam strikes the level of the roadway on which the vehicle stands at a distance of more than seventy-five feet from the vehicle.
B. A person shall not drive or move a vehicle or equipment on a highway with a lamp or device on the vehicle that is capable of displaying a red or red and blue light or lens visible from directly in front of the center of the vehicle. Lights visible from the front of a vehicle shall be amber or white. This section does not apply to an authorized emergency vehicle or a vehicle on which a red or red and blue light or lens visible from the front is expressly authorized or required by this chapter.
CarStuff
Dec 6, 2020 12:52 PM
NeoMagus
Nov 30, 2001 08:54 PM
GhettoCivic
Nov 12, 2001 03:15 PM
2k1TypeR
Sep 25, 2001 09:25 AM
