I dropped of the head to be milled. Should I be scared?
Old Nov 4, 2004
Rufus's Avatar
Ok so Honda says don't mill over 2 mm. Gearbox on this site supposedly had his done 1mm over by DH Racing. Well 3 mm equals abouts .118 thousandths. He seems to be ok running it munis the rough idle. So I had them do it .10 thousandths or 2.54mm. So now the head is ported and polished, milled, and ready to go. I'll put it on in the next couple weeks and let you all know how much it helps. I priced nitrous today and the best I found was 487 for a ZEX 82021 kit new. I think ebay will have to be the solution.
Old Nov 4, 2004
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
i would look around for a back up motor to, just incase the nit. and head work dont like the az heat.... hope it works out! should dyno it when all is done.
Old Nov 4, 2004
I think with our engines, the increase in compression isn't gonna matter much anyway. If you can install the head bolts without them bottoming out, you should be okay.
Old Nov 4, 2004
topnotch7gen's Avatar
JDM-Jonathan David Martin- I own everybody
topnotch7gen is on a distinguished road
Don't go with ZEX , get NOS or NX. If you got the money get direct port instead of single fogger, lot better for spray.
Old Nov 4, 2004
JoeyOKC's Avatar
http://ackakaka.ytmnd.com
JoeyOKC is on a distinguished road
NX wet-kit would be my suggestion...
Old Nov 5, 2004
Rufus's Avatar
Since I went with less of a mill than you have I'm sure I'll be ok. However anytime you can make the combustion area smaller you're going to have an impact. While I agree it may not be noticeable on our cars I think we all agree that everybit helps. Thanks Gearbox, I think you're the only member that I was able to talk to about it beforehand. Anyways I'm looking at the Wet nitrous kit anyway. Since our returnless fuel system can't regulate pressure, if I used a dry kit, the injectors couldn't compensate for the extra oxygen and I'd run lean. I have a really cool idea to make a bottle holder in the trunk that floats above the subs and is directly bolted to the strut mounts.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Sarahwv2910
22
Jun 17, 2015 12:35 PM
Supramk3
May 11, 2015 07:55 PM
aZnVoYCe
Dec 23, 2001 09:56 PM
aZnVoYCe
Dec 23, 2001 12:39 PM
