LABOR HELP: dropping my sedan
Originally Posted by n20hcvc
Maybe we can have a tech day where (JT) and I can both do suspension work because I get my Koni's in a week hmmm....
j/k JDM-Jonathan David Martin- I own everybody
Originally Posted by AZNRACR
I guess i'm not invited to the tech day then?
j/k
j/kalso, sedan springs will fit on coupes and since I had them on my car I saw no sagging.
Civicforums Junkie
*theres a reason why the spring companys have different part numbers for the coupe/sedan*
sedan springs will fit (and work) on the coupes...
no problems
coupe springs will fit (and work) on the sedans...
but if you do this, the rear will sag since the sedans have heavier rears
no problems
Alrighty sorry my net was down so I'm back and all this is goin on JEEZe! Sure I dont mind helpin paint houses, if there is beer and pizza(or bbq!) involved!
Well I have a lil technique developed from many a spring install for safely(relatively
) relieving spring tension from the whole spring/strut assembly. Sounds like you already have tried variants of it. All the Accords I've done are under a lot of tension(they got big asses!). Heh the only crappy thing is recompressing the new spring, usually eibachs(prokit) are the biggest offenders of needing a big dude to press down on the spring hat hehe. Any other springs are cake tho as they fit nicely on the strut...
FALKEN you should be pretty happy with the Neuspeeds I had sports on my car previously(traded up to c/o's) and they didnt blow the stock struts over 2 yrs of use. Same thing with my moms old car(6th gen Accord she now drives an 04Si) and both my parents were ok with the slightly stiffer ride in their car...
So this is happening out in Glendale area?
Peace
) relieving spring tension from the whole spring/strut assembly. Sounds like you already have tried variants of it. All the Accords I've done are under a lot of tension(they got big asses!). Heh the only crappy thing is recompressing the new spring, usually eibachs(prokit) are the biggest offenders of needing a big dude to press down on the spring hat hehe. Any other springs are cake tho as they fit nicely on the strut...FALKEN you should be pretty happy with the Neuspeeds I had sports on my car previously(traded up to c/o's) and they didnt blow the stock struts over 2 yrs of use. Same thing with my moms old car(6th gen Accord she now drives an 04Si) and both my parents were ok with the slightly stiffer ride in their car...
Peace
no problems
no problems
ok, so I just put skunk2 springs on my 01 sedan and the back looks perfect sits right above the wheel well approx 1 finger gap but the front is like a 3 finger gap. Is this because skunk2 doesnt make a spring for the sedan and it is really for the coupe and my rear is saggin. I want the front to look exactly like the back.
Civicforums Junkie
Originally Posted by thejibb
just gimme a ring sometime and we can either set up a time for me to come by and help or i can just lend you the manuals...
Civicforums Junkie
it took me about 4.5 hours...
i kept getting interrupted by the wife
couldnt get the tie-rods off after trying for an hour
(i finally found my tie-rod seperator and got them off in 10min)
the rears were also hard to get at from the inside (the access is different on the coupes)
dtdoyle
25
Aug 30, 2015 06:57 PM
GritzNGravy
Aug 19, 2015 03:03 AM
alaga
25
Aug 13, 2015 04:42 PM
redcloud
25
Aug 12, 2015 01:23 PM
