whats next?
Re: whats next?
i need to remount my rear bumper(electrical wire FTW)
also replace pass.fender
get rid on my little rusty spots
replace my driver`s side mirror
replace the thermostat
new marker light surround
and then i can start modding
Re: whats next?
I got my Konis! lol
New headgasket is on. I pickup my freshly painted frontend tommorrow with a shaved license plate..
Civicforums Junkie
Re: whats next?
heres what i did this morning...
STEP: 1
tape off around the headlight so you dont sand your precious paint job
STEP: 2
wetsand the headlight
(use 800 grit if the lens is really bad)
(use 1000 grit if lens has normal issues)
STEP: 3
wipe headlight dry
STEP: 4
(use 1000 grit if your first sanding was 800 grit, then move on to 2000 grit)
(use 2000 grit if your first sanding was 1000 grit)
STEP: 5
wipe headlight dry
STEP: 6
buff headlight using plastic polish/cleaner
(i used a drill attachment to speed the process)
FINAL RESULTS:
STEP: 1
STEP: 2
STEP: 3
wipe headlight dry
STEP: 4
STEP: 5
wipe headlight dry
STEP: 6
FINAL RESULTS:
Re: whats next?
My next project (in order)
-Hondata intake manifold gasket
-Throtle body spacer
-Cold Air Intake
-Eibach Sportlines lowering springs
-TOE correction
-DCRH
-AEM pulley kit
-Honda reflash
and done sell the car and start over again lol (with S2k or CRX)
-Cold Air Intake
-TOE correction
-DCRH
-AEM pulley kit
-Honda reflash
Re: whats next?
Nope you neither!
NO!
