1/19 n2o track times (update with vid!!)
Old Jan 22, 2006
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
ok this was my first time out to the track with n2o. I was running a 75shot, I believe there is alot of room for improvement though.
1st. 14.4@101 w/ 2.5 60ft
2nd. 14.5@100 w/ 2.5 60ft
3rd. 14.3@99 w/2.4 60ft
I know I can do better if I get my 60ft down, but im still figure things out.
Edit: Hey guys I found out a local friend had taped my 14.3 run. so here it is.
I watched this vid over and over and my jaw drops everytime I bog lol.
Click here to watch My-civic-vs-Gto
Old Jan 22, 2006
ajhdragon's Avatar
7thgens official a$$hole
nice times what gears/rpm range were you spraying?
Old Jan 22, 2006
Jspek Inspired
i start spraying 1st gear @ 3500rpm to just about redline, I was told by someone maybe I shouldnt start spraying til 2nd gear.
Old Jan 22, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Wow, 100+ mph trap speeds! damn nice job. Us nitrous people need to get into the 13's.
Old Jan 23, 2006
Jspek Inspired
yea im hoping next time with better tires I might be able to get into 13's.
Old Jan 23, 2006
Jrfish007's Avatar
Well... you have 2 things to consider for when to spray.
1. if you spray in low gears you are putting far more power down to the tires than normally and you will break something quickly, probably axels or something like that. then you upgrade the axels and the tranny goes. Remember you are multipling the torque created by the engine through the tranny, which will put quite a bit of stress on it.
2. If you can keep traction while spraying in low gears, why not? lol I mean axels aren't that much, and junk yard trannies can be had for just a few hundred (assuming you are using a manual). The question is do you have the funds and can you afford the down time if something does break?
Old Jan 23, 2006
djmota's Avatar
street tires?
those are good traps. with a lower 60 ft time you should be at 14.0-14.1 your trap will go down as you get better 60 ft times but your times will improve keep practicing your times will always get better.
Old Jan 23, 2006
Jspek Inspired
Originally Posted by djmota
street tires?
yes they were on street tires. the next time out, ill be borrowing a friends drag radials so I hope that will help alot.
Old Jan 24, 2006
Jrfish007's Avatar
I would think drag could get you into the 13's with a little practice and having the axel gods smiling on you. I've seen cars slap a set of drags on and cut over 0.5 seconds, but those where RWD cars, but it'll be interesting to see
Old Jan 24, 2006
Michalo187's Avatar
Abortion Survivor
pretty good times and good luck into the 13's keep us all updated
Old Jan 24, 2006
turboengnr's Avatar
DONT PANIC
damn....
I went 13.9 @ 100.3 (2.067 60/ft) and 13.6 @ 102 (2.042 60/ft)
So you are damn close to a 13 if you can learn to drive (no offence)
Old Jan 24, 2006
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
I sprayed for a while with a 75 shot myself and used drag radials too and never broke any axels nor have I ever heard of any member on this site breaking any of their axels due to using nitrous. Not saying it couldnt happen but I think its very unlikely unless they're making a lot more whp/wtrq than the average 7th gen nitrous member.
Old Jan 24, 2006
Jspek Inspired
Originally Posted by turboengnr
damn....
lol none taken, i'll get it down eventually.
Old Jan 26, 2006
Jspek Inspired
bump with vid now.
Old Jan 26, 2006
turboengnr's Avatar
DONT PANIC
oh yea, horrible launch. Also looked like you short shifted 1st. Even though the tires are breaking loose, dont shift right away. Try doing the same thing you did there with drag radials, but launch at a higher RPM. If you still lose traction badly in 1st, dont use the nitrous til 2nd.
If you could pull a 2.2 or better 60/ft, you would definately be in the 13's.
I have faith in you! When i first started running my civic at the track, i was getting 2.7, 2.5, etc 60/ft.
Now i can pull 2.1 and 2.0 consistently. After you rack up a few hundred slips, you will have it down no problem.
Old Jan 26, 2006
Jspek Inspired
^^ yea i short shifted 1st cause i've heard that you dont want to hit rev limiter on n2o, unless this is a myth then ill ride it out next time.
thanks turboengnr, maybe i can be the first into 13's with n2o
Old Jan 26, 2006
turboengnr's Avatar
DONT PANIC
you are correct. n2o + rev limiter can cause problems.
I keep forgetting that. Im a turbo guy, so rev-limiters dont bug me.
Im not blaming you for short shifting anymore. lol.
Old Jan 26, 2006
Jrfish007's Avatar
I did but it wasn't 7thegen so it doesn't count, did it in my old '94 civic
Just curious though, how many spray in 1st gear?
Old Jan 26, 2006
djmota's Avatar
I spray in first. you don't have short shift, just cut it close. If you misshift let go off the gas.
Old Jan 26, 2006
turboengnr's Avatar
DONT PANIC
hey azn, do you have a window switch installed?
If not, get one and put in a 6500 RPM pill. Then you wont have to worry about the rev-limiter + nitrous
i know, im really lagging on my answers. But give me a break! Im medicated!
Old Jan 26, 2006
Same here
Old Jan 26, 2006
Jspek Inspired
no problem man, I would buy a wondow switch, but then again I have a new motor going in this summer, so therefor I dont feel the need to buy one.
Old Jan 26, 2006
2k4ex's Avatar
2k4ex is an unknown quantity at this point
Hey azn, what other mods do you have done to your car?
Old Jan 26, 2006
Jspek Inspired
Simota racing intake, dc race header, hks axleback, act prolight flywheel, exedy clutch, viscous tech short shifter adapters, untuned VAFC2, some sus mods.
