2 days of AUTOCROSS!!!!!!! Now with results and Photos
Old Oct 1, 2003
Zzyzx's Avatar
Autocross Junky
This weekend!! in the Midway lot at the Las Vegas Motorspeed way the Local SCCA is having Round 17 and 18 of the 2003 season. Every one is invited to come Race!
Check in on Saturday Oct 4th opens 7:30 am - First car out at 9!
entry Fees are $25 for members, $30 for non members
we average 10-12 runs for the full day, and each run lasts about 50-60 seconds.... So you'll get plenty of track time.
If you cant make the Saturday event, we do it all over again on SUNDAY!!!!!
What more could you want?
Directions:
LVMS is about 30 minutes north of Las Vegas on Highway I-15. Once you pull off at the speedway, you'll see us set up in front of the main grandstands.
Your First event could be FREE!!!! You cant beat FREE!
Just Print this Flyer and bring it with you to Registration
So How can you pass up 2 days of tire squealin racing for only $30????
See ya at the races!
Spencer #409 STS
Old Oct 2, 2003
02SilverSiHB's Avatar
K Motor Lover Baby!
02SilverSiHB is an unknown quantity at this point
looks like fun
Old Oct 7, 2003
Zzyzx's Avatar
Autocross Junky
Here ya go, Autocrossin at its best (I wish)
So the two days of racing were Great! I ended up Taking 1st place both days!!!!!
Woo Hoo!!!!
Old Oct 7, 2003
K Motor Lover Baby!
damn man! congrats. I can't wait until the next autocross day here. No word yet on an October event, they had to go out and find a new place The place they were using, was the Alamodome...change of season and all.
Old Oct 7, 2003
flotsamm's Avatar
Woowoo! Way to represent! Good job man!
Old Oct 7, 2003
Green Civic's Avatar
Sweet. Good runs. What mods can you have before you are placed into the STS class?
Old Oct 7, 2003
robbclark1's Avatar
Retired suspension supermod.
you da man now dawg! If i only i could drive like you. i suck!
Old Oct 7, 2003
Zzyzx's Avatar
Autocross Junky
STS is a pretty limited prep class, so there not that much you can do onece you're in STS. the only class lower then STS is stock. But you can do some things in stock, Like get aftermarket shocks, but you have to keep the Stock springs...
Complete rules for both classes can be found HERE
The basics
Stock
Anything available on the exact model and year of your car as standard or optional equipment, as installed on the factory assembly line (nothing available only dealer-installed is allowed), plus
Standard OEM identical replacement parts
Accessories, gauges, appearance, comfort, and convenience items (not replacement driver's seat, though) that basically don't help
Added roll bar or roll cage to spec (not required, though)
Driver harness (no cutting seats to install, though)
Trailer hitch and/or tow bar mountings
Any wheel of diameter and width identical to a stock or factory optional wheel, offset within +- 0.25 inch
Most street legal tires that will fit the mounted wheels and stock bodywork
Any shock absorber of the same type and mounting as original; no change to standard spring mountings is allowed; suspension geometry may not be altered; gas or hydraulic shocks are permitted
Any brake linings; pre-1992 cars may use solid/braided metal brake lines.
Any front anti-roll bar (no change to stock/optional rear anti-roll bar, if present)
Manufacturer specified ignition settings only
Any replacement air filter element (or removal of air filter element); no plumbing changes, however
Engine bored no more than .020"; no balancing or porting/polishing of head
Replacement of any part of the exhaust system past the catalytic converter (if quiet)
Any oil filter
Added clutch scattershield
STS
If your car is a normally aspirated sedan (four seats, four factory seatbelts, not sports-car derived) of 3.1 Liters or less, or one of a few small turbocharged cars specified in the rules, and perhaps prepared further than allowed in Stock Category, it may be eligible for one of the Street Touring Classes. Street Touring - S is an SCCA National class, but Street Touring-R is an optional Regional only class. Street Touring allows anything allowed in Stock, plus (roughly) these modifications:
Any shocks, struts, and springs, using original attachment points
Any sway bars
Any wheels up to 7.5" in width that fit over stock brakes
Tires up to and including a width of 225, with a treadwear rating of 140 or greater.
Strut bars/braces as allowed in Street Prepared.
Exhaust system downstream of catalytic converter(s)
Short throw shift kits
Spoilers, body kits, rear wings, etc.
Pedal kits and other interior cosmetic accessories
Alternate brakes pads and linings
Any fully padded and upholstered front seats with reclining seat backs
Removal of factory trim (rub strips, emblems)
Alternate steering wheels of any diameter, otherwise meeting Stock rules
Cross drilled and/or slotted brake rotors
Alternate air cleaner enclosures
No limited slip differentials except factory viscous coupler type units
Stock brake calipers/drums
Fenders may not be cut or flared (but specific modifications for tires OK)
Emission-legal headers
Emission legal modifications to Engine management system, either electronic or mehanical, but not both.
Engine and transmission must remain unmodified, including emissions equipment
