OLD - Group Buys A Vendor's place to post information concerning "Honda Civic Group Buys" only here.
Only Approved Honda Civic Vendors are allowed to post here
Optima Battery GB
Old Jul 26, 2004
dezod's Avatar
7thgen Power Maker
Optima Battery GB
Need 2 buyers:
Yellow Top $125 plus s&h
I have quite a few of these in stock and ready to ship as well. Price good through 8/31/04. NYS residents are subject to 8.25% sales tax. Shipping is based upon geographical location from Dezod Motorsports to your location. Usually ranges from $12-30. All items as of Today are in stock and ready to ship.
SHIPPING QUOTES FOR US CUSTOMERS CAN BE ASCERTAINED THROUGH OUR SHIPPING CALCULATOR ON OUR SITE.
To order go here:
http://www.dezod.com/pd_optima_yellow.cfm
Old Jul 26, 2004
teampointless's Avatar
Ultimate Member
i'm in for this also if anyone else is....
Old Jul 26, 2004
cosmo's Avatar
cosmo is an unknown quantity at this point
How much shipped to Canada?
Old Jul 26, 2004
dezod's Avatar
7thgen Power Maker
Need your postal code.
Old Jul 26, 2004
cosmo's Avatar
S4X 4A6
Old Jul 26, 2004
dezod's Avatar
7thgen Power Maker
S4X 4A6
$38 (because of the weight)
Old Jul 26, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
what about reds?
Old Jul 26, 2004
dezod's Avatar
7thgen Power Maker
Originally Posted by chocobo15_2000
what about reds?
This is for yellow only Choco...........This is the only one they make this comparabel to our stock. If you want to purchase a Red still......pm me.
Old Jul 27, 2004
scbgilbert's Avatar
scbgilbert is an unknown quantity at this point
Battery
What about to V2G 5K8 in BC, Canada????
Old Jul 27, 2004
7gencivicboi's Avatar
7gencivicboi is an unknown quantity at this point
whats the differecences between yellow, red, etc.????
Old Jul 27, 2004
AlpineCivic's Avatar
how much shipped to 91746?
Old Jul 27, 2004
dezod's Avatar
7thgen Power Maker
Circa $15-16.00
Old Jul 27, 2004
dezod's Avatar
7thgen Power Maker
$48 TO THAT POSTAL CODE
Old Jul 27, 2004
dezod's Avatar
7thgen Power Maker
The OPTIMA Yellow Top™ Deep Cycle Battery should be used in the following cases:
Starting applications in high-accessory vehicles/High Cycling Applications. Vehicles with computers, extra radios, electronic components, lights, winches, etc. will create excessive amperage drain that can damage a starting battery. Recommend the OPTIMA Yellow Top to provide fast recharging and longer life due to its' ability to cycle over 300 times.
Starting applications with low amperage draws. If your customer has a vehicle that sits unused for long periods of time, either OPTIMA will provide longer life due to reduced corrosion and sulfation. However, if the vehicle has an alarm, computer, or other low amperage drain, the Yellow Top will guard against deep cycling damage that can occur over long periods of time.
To increase Reserve Capacity or Run Time. You must first identify how long the customer needs to use the battery to run a vehicle, accessory, or motor before without recharging. Each OPTIMA Yellow Top Deep Cycle Battery is rated at 120 minutes of Reserve Capacity at a 25 Amp draw. If your customer is planning on using their OTPIMA in a trolling motor that pulls 50 Amps, they will only get 60 minutes of run time. If they require more run time you need to install multiple batteries in parallel. It is important to understand what the customer expects in order to provide them with the correct OPTIMA solution.
Remember:
Dark Gray Case means Starting TechnologyLight Gray Case means Deep Cycle Technology
In any vehicle or equipment that will use the battery only for Starting, Lighting, & Ignition requirements and has a properly working alternator, the OPTIMA Red Top™ Starting Battery will perform extremely well, often providing up to two times longer life than conventional batteries. If the vehicle has few or no after-market accessories and uses a stock or upgraded alternator, the OPTIMA Red Top Starting Battery is the appropriate choice.
Remember, it is possible for the customer to have a completely discharged Red Top OPTIMA that will not start their engine; the advantages of the Red Top are that it can accept a rapid recharge and it will recover from discharge many more times.
To provide the customer the best OPTIMA solution, it is, necessary to consider both the application and the charging system before recommending the correct OPTIMA. For example, if your customer has a Ford Expedition with an after-market alarm system, which OPTIMA would you recommend? If the customer drives the car every day, the Red Top would be the correct choice, since the amperage drain will be nominal and the battery would be recharged on a daily basis. However, if the customer stores the vehicle for a long period of time with the alarm system engaged, you should recommend the OPTIMA Yellow Top, since the amperage drain over several weeks would damage a Red Top and reduce its life.
http://www.optimabatteries.com/usingOptima/index.asp
Old Jul 29, 2004
dezod's Avatar
7thgen Power Maker
up up
Old Aug 4, 2004
dezod's Avatar
7thgen Power Maker
ha ha ha
Old Aug 6, 2004
dezod's Avatar
7thgen Power Maker
Quite a few of these left too
Old Aug 10, 2004
seijin_av's Avatar
seijin_av is an unknown quantity at this point
how much is shipping to 96821? and, if you can tell me how to kill my battery so it can't be recharged..... then i'm in =)
Old Aug 10, 2004
seijin_av's Avatar
p.s. TURBO KIT!!!! ahhh sorry i'm jacking the thread with your own turbo kit... =P
Old Aug 10, 2004
dezod's Avatar
7thgen Power Maker
Shipping is circa $45.00
Old Aug 10, 2004
seijin_av's Avatar
meh $45 to ship.. i'm going to have to think about this... =/
Old Aug 10, 2004
dezod's Avatar
7thgen Power Maker
It's heavy and comin from FAR east coast (Buffalo, NY) to you in HI via Express Saver.
Let me know.
Old Aug 10, 2004
seijin_av's Avatar
i'll probably get one in a bit... i just need to give my dad a reason to get a new one... aka killing my battery =) and noo, he's not paying for it, i am.
Old Aug 16, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
so wats the blue one for
Old Aug 16, 2004
dezod's Avatar
7thgen Power Maker
Marine/RV Battery
OPTIMA Blue Top batteries, featuring SPIRALCELL TECHNOLOGY, are designed for all of your marine and RV, starting and deep cycle needs.
Vibration Resistant
The constant vibration and jarring from waves can be deadly for traditional marine batteries. The tightly wound construction in OPTIMA batteries minimizes plate movement and subsequent damage caused by harsh conditions - extending battery life.
Constant Performance Quality
OPTIMA Blue Top batteries provide constant performance quality as they are discharging. Even as energy is being drained, your equipment will perform at the same level as when the battery was fully charged. Meaning, you will not hear or feel your equipment slow down or strain for power.
Nonspillable
Because of its completely sealed case, OPTIMA Blue Top batteries are extremely safe. Acid can't leak or spill, making them clean, user-friendly and environmentally sound. In addition, the maintenance free sealed case design eliminates the need to add water or clean terminals.
Retains Charge / Recharges Faster
Marine batteries sometimes sit for months at a time and lose their charge. But the OPTIMA Blue Top battery has such a low rate of self-discharge, that it can go unused for up to one year without recharging, if it's kept at room temperature or below. And because of its low internal resistance, it recharges faster, getting you back on the water quickly.
Mounts in Almost Any Position
OPTIMA Blue Top batteries are leak proof, so they can be mounted anyplace inside boats or RVs, in almost any position.
Old Aug 16, 2004
sounds like the blue is good for our cars cause its vibrates alot.. also its good if you have a sound system cause it will perform, bass will keep kicking the same and the highs will still be highs.. lol.. but then i dont know anything about batteries
Old Aug 16, 2004
dezod's Avatar
7thgen Power Maker
Yellow top is best for systems
Old Aug 19, 2004
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
shipping to 21042?
Old Aug 19, 2004
dezod's Avatar
7thgen Power Maker
Originally Posted by Civictuner04
shipping to 21042?
circa $17
Old Aug 20, 2004
dezod's Avatar
7thgen Power Maker
Up!!!!
