pioneer avic-d3 install question
Old Apr 4, 2008
yingjai's Avatar
yingjai is an unknown quantity at this point
I currently have an Apline cd deck installed. Do I need a new wiring harness in order to install the d3? Best Buy said it's not recommended to use the old Apline harness on the d3, but I want to double check before I buy the cable on Monday.
Old Apr 4, 2008
SEN_ONE's Avatar
SEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of light
Re: pioneer avic-d3 install question
The after market wire harness will be universal. You don't need a new one. They may have thought you meant the harness that plugs into the Alpine unit, not the one that plugs into the factory wiring.
Old Apr 4, 2008
yingjai's Avatar
good. nice and quick answer too. thanks.
i'll post pix after install.
Old Apr 4, 2008
SSMCivic2k5's Avatar
SSMCivic2k5 has a spectacular aura aboutSSMCivic2k5 has a spectacular aura aboutSSMCivic2k5 has a spectacular aura about
you cant use any harness on the d3 because its a mobile radio.... you gotta get a new one and strip the wirings and connect that to the D3..... I had d3 in my car.... its sweet, but get used to not using CD's anymore just put everything on ur ipod...if u want the bypass for it hit me up!
Old Apr 4, 2008
SEN_ONE's Avatar
He already has an after market H/U. Unless he cut his factory harness, he should have the adapter harness for his car. That's all he needs. I just installed my D3 about three weeks ago, bypassed and all. There isn't a "special harness" made for the D3. Go here to learn anything, and everything you can do with the D3. Bypass, wallpapers, NAVI disc, ect....
Old Apr 4, 2008
noo i know that.... all u need is the aftermarket harness and strip the harness off...
