possible boost build..questions
Old Dec 2, 2007
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
I wana do this in about a year but I wana know stuff so I can snag good deals if they come along in the meantime...want to run 6psi and shooting for 160-175whp...can it be done? here we go
manifold-t25 HKS cast iron
turbo-t25 duno what kind to get though...DSM? or from another source, i was thinking a 14g
injectors-what are the cheapest ones i can get that will flow enough
engine management- e-manage blue?? anything cheaper i can get? someone mentioned something about chrome
intercooler-need size suggestions...can i use an ebay one...what about a side mount maybe?
IC piping-custom made
exhaust-will 2.25 do?
bov-someone told me to use a 1g DSM BOV
clutch-stage 1 exedy?
gauge-any specific brands?
any other suggestions..dont need big power, just want a nice responsive snappy car
Old Dec 2, 2007
spoonEM's Avatar
omgwtfbbq mod.
Re: possible boost build..questions
There are a ton of threads about this...you need to search around.
Old Dec 3, 2007
skipbarber's Avatar
-not a bad choice, functional and reliable..
-dont get a used turbo
-RSX-S injectors will flow perfectly for 6psi, and they're starting to go pretty cheap, usually under $90 a set.
-crome works on EPROM OBD1 cars, so good luck with that. everyone on this forum knows that the emanage at least works..
-FMIC is always best, but ive seen sidemounts work, but youd have to move your battery to the trunk (more $$) I suggest trying to find a setup in the sale forum.
-not too hard to do, just about anyone that can weld can fab up some pipes for you.
-more or less, 2.5" would be ideal, but a 1/4" wont kill you.
-for low boost, sure. id rather get a recirculation valve if i were boosting on a low budget.
-some people may not like what im about to say...but the stock clutch is FINE. i beat the living **** out of my clutch at 8 psi, daily driving it for well over a year AND taught my gf stick. When I pulled it out to install my stage 1...it looked freaking new, yes, the original 2002 clutch was only a few hundreths of an inch thinner than my brand new clutch. It held 180 whp like a champ, never slipped and put side to side with the exedy stage 1, you cant even tell a difference, same logos, very similar compounds. honda put a good clutch in these cars. however, thats been my experience, if you know your clutch is going, or will be going soon, the stage 1 is nice. firms up the pedal a little bit and engages really smoothly. i like it.
-DEFI, dont know if they still make mechanical gauges, but i have one, and it was cheaper than most others and it's very accurate. dont forget to get atleast a wideband and id also suggest an oil pressure gauge. boosted cars are good at losing oil, and i killed my first motor as a result. just a good thing to keep an eye on.
other suggestions:
-use an oil filter housing sandwich plate to source your oil feed instead of trying to tee into the factory oil pressure sender. I have a goldeneagle version, but i know there are plenty on the market.
-the goldeneagle vacuum manifold makes it easy to route all your vacuum hoses.
-get a good tune. get a good tune, get a good tune, get it? a good tune will save your motor.
-FREAKIN' SEARCH MAN, THESE AND MANY OTHER QUESTIONS HAVE BEEN ANSWERED MANY TIMES BEFORE.
-im sure im forgetting something, i'll add it if it comes to me.
good luck and dont become an addict to boost, you'll want to crank it up and your wallet will be lighter, alot lighter.
Old Dec 3, 2007
speedfoos's Avatar
I agree with everything Edwin said except his last sentence. I can take my turbo kit off anytime I want to, I don't need more boost. There's nothing addictive about it....
My recommendation for the EMS on a budget build is the AEM F/IC. You can get the whole thing for about $600 with the harness and it comes with an onboard MAP sensor so you don't have to spend another $75 (like with the PCS or Greddy) on an external one. I have no personal experience with it, but folks are having good luck with it on mild builds.
Don't forget new plugs, vac line, clamps, couplers, gaskets, and all the other nitnoid stuff that adds up in a real hurry.
Old Dec 3, 2007
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
go AEM F/IC...I got it with 7lbs...its great man...never used e-manage but I heard it can be a biaaatch at times
Old Dec 3, 2007
Technical Assistant
Yes I know I need a good tune, we have good guys around here, I can always get it done at a shop that uses Evan's. Also, will I be able to reach my target power with a bare 6psi? And, ive never heard of the AEM F/IC, I thought that e-manage blue would work, and its cheaper at only 300 bux
Old Dec 3, 2007
PitchBlack's Avatar
Emanage with no addons or plug and play harness is 300 bux. The AEM F/IC with all the bells and whistles is just under 600 with the plug and play harness. You can hardwire it and save the extra couple hundred bucks for the plug and play if you want. Its kind of a pain in the *** though. Emanage will never stack up to the AEM F/IC even if you do spend the money and get all its addons which in the end will cost more than the AEM setup.
Old Dec 3, 2007
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Read Paul's write up on emanage vs f/ic.
https://www.civicforums.com/forums/7...-e-manage.html
FYI if you do end up using a DSM turbo it's not going to bolt up to the HKS manifold.
Old Dec 3, 2007
Technical Assistant
What about a saab turbo? sr20 turbo?? I heard that the DSM one doesnt bolt up but noone told me why
Old Dec 3, 2007
familycar's Avatar
the footprint for the exhaust housing doesnt match up to the manifold flange
Old Dec 3, 2007
Technical Assistant
for the DSM one or all of them...would a DSM manifold fit our cars??
Old Dec 3, 2007
skipbarber's Avatar
you cant seriously be asking that question.
Old Dec 3, 2007
familycar's Avatar
your making this harder than it has to be. the manifold from HKS fits a t25, a DSM manifold is for a DSM not a civic, so you answered your own question. if you want to run the HKS manifold you NEED a t25 turbo, but you should not choose your turbo based on the manifold, it should be the other way around.
Old Dec 3, 2007
Rennen's Avatar
New Mod on the Block
everyone has already answered your questions. and this topic has been covered before. please search.
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
