New Speakers And Flush Mount Tweets
Old May 19, 2007
snobird's Avatar
snobird is an unknown quantity at this point
i got the polk db's 6.5 inch component set. i got one set for front and rear and installed the tweets flush mount installed, these things sound amazing and more stuff being installed soon so look foward to new pics.
let me know what you think:
Old May 20, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Re: New Speakers And Flush Mount Tweets
Very nice install. What did you use to cut the tweeter holes? That was the only thing that stopped me from buying components...no power cutting tools.
Old May 20, 2007
paradoxblue's Avatar
yeah id like to know also?
ill have to look these up. did u fab mounting rings for the speakers?
Old May 20, 2007
snobird's Avatar
my guy used a circular type saw bit that was on the end of the drill, they make them to drill certin size holes here is an example:
http://www.diamond-drill-bit-and-too...-Drill-Bit.htm
and the rings were included, the kit came with a flush mount ring
Old May 20, 2007
$killer05coupe's Avatar
$killer05coupe will become famous soon enough$killer05coupe will become famous soon enough
Nice! i like the rear installs!
Old May 20, 2007
electric130's Avatar
very nice!!! clean install. what size hole saw did your buddy use?
off topic, but why is your passenger handle black instead of gray like the drivers side? mine are both gray. did you replace one?
Old May 20, 2007
dizbstretch's Avatar
dizbstretch is an unknown quantity at this point
nice install man... i got the same speakers in my car too.. yes they do sound amazing... the beginning when you turn it up too high, it sounds weird, but when the speakers settles down and you use it quite a bit, it sounds sweet... i never though of mounting the tweeters on the rear panel like you did, i was thinking on the rear doors, but sweet install man... enjoy
Old May 20, 2007
snobird's Avatar
thanks guys for the good feedback and when we bought it from auction the black piece was grey but damaged and i had a black one on hand so i replaced it but i do need to get a grey one
Old May 22, 2007
randy6duece's Avatar
randy6duece will become famous soon enoughrandy6duece will become famous soon enough
that looks good ima have to do that as well for the rears...
Old May 22, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
very nice.
next time post up a DIY!
Old May 22, 2007
did you amp them?
Old May 22, 2007
boinam's Avatar
boinam is an unknown quantity at this point
I would love to flush mount my Polk tweeters, but I don't have in my possession the 2 inch hole saw needed to cut the hole. Very nice install by the way, I just put my db 6x9's in the rear.
Old May 22, 2007
you can buy one at Lowe's for $10.
Old May 22, 2007
drew22mader's Avatar
There is gl@ss in my @SS...
Nice speakers but installing components in the rear is very unecessary. You don't want all your sound coming from the rear, your imaging should be focused from the front and you should almost feel liek the sound is coming from the center of the dash. In my car the rear speakers were upgraded to 6 1/2" Coax and turned down so you just have rear feel. I suggest turn the rear speakers down to where you can barely notice them.
Old May 22, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
x2, I was wondering if anyone was going to point that out.
Old May 24, 2007
snobird's Avatar
thanks for all the good replys guys
the circle saw is not expensive like electric130 i think eevn walmart has these for like 3 or 4 bucks
also drew22mader and chris the car is set up to be fully tuned around me when i sit in my car i sit kinda leaned back and right at the middle pillar maybe a little behind sometimes so im bascially in the direct center of the car with the tweets that way its directed sound all to center of car and sounds amazing
Old May 24, 2007
but it's not supposed to be coming from the center of the car, it should be coming from the center of the dash in front of you like a concert would be.
Old May 24, 2007
chicohonda02's Avatar
Since 2002 Baby!
looks good. i've been wanting to do that too
redcloud
Aug 26, 2015 11:27 AM
WaryDriver
Aug 8, 2015 05:08 PM
honda.lioness
Aug 6, 2015 11:58 AM
Nalmonte
Jul 22, 2015 09:08 AM
