side panels from RSX 03-05... would it fit on our 7thgen 03-05??
Rep Power: 226 side panels from RSX 03-05... would it fit on our 7thgen 03-05??
As the title says..well i've been searching and apparently no one really did this so i was wondering if some of ya 7thgener might know if this will work.. iam absolutely sure that steering wheel, sway bar, seats and Cluster will definitely bolt on in our car..
J
J
TURTLEonK
Rep Power: 267 by side panels do you mean the door panels? they will fit but you will need to custom fit it in order for it to clear when you shut the door. you will also need to swap the dashboard, etc.
The cluster may be a bolt in but you will need to re-wire everything for it to work.
Rep Power: 219 actually the cluster is not a perfect fit. Other than rewiring there is a small space at the bottom of the cluster after its installed. Someone here has done it.
timpan
05-18-2015 07:06 AM
ej8
04-13-2015 06:36 PM
