lowering spring!!
Old Mar 18, 2006
wsccd3's Avatar
wsccd3 is an unknown quantity at this point
lowering spring!!
yay today i put the header and the downpipe on my civic!!
hmmm but no big difference.... cant feel the difference.... juss lil....
any ways while i was on it i was going to put the lowering spring too... but my friend told me that if i juss put only the spring, my wheels will look like this /------\ and only one side of the tire is going to be out.. and im gon have to change the tires.......... is it????
* i got the "megan lowering spring ( organge) "
Old Mar 18, 2006
matt_s's Avatar
Super JDM Member
matt_s is an unknown quantity at this point
lol well /....\ is called negative camber. The lower u go the more camber you will have. To fix this you do not need new tires... u need to purchase an aftermarket adjustable rear camber kit, and that will solve your problems. The fronts wont be affected by camber unless its crazy low...an alignment will fix the front toe..
Old Mar 18, 2006
wsccd3's Avatar
right alignment will fix it right?? then do all the lowering spring make the wheels like that?? of if i lower it than the normal lower.... the one i got is about 2" drop.......
Old Aug 6, 2006
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
well, get a camber kit first.. if you can install it your self then do it. after that get an alignment if you think the car still looks /---\
you what the spc rear camber kit or other stuff like eibach.
Old Aug 6, 2006
navysooner's Avatar
navysooner will become famous soon enoughnavysooner will become famous soon enough
alignment will not fix negative camber. Alignment is how far the car drifts the left and right.
Old Aug 6, 2006
tdac69's Avatar
tdac69 will become famous soon enoughtdac69 will become famous soon enough
i dont no
Old Aug 6, 2006
30seconds's Avatar
30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light30seconds is a glorious beacon of light
^^why the hell did you post in this than you dumbass
rear alignment will not fix it..you need a camber kit like everyone else said, they dont cost a lot and are easy to install
Old Aug 6, 2006
SLO REX's Avatar
250+ awhp Stage 2
Originally Posted by tdac69
i dont no
Fvcktards ftl! Why would you post that you don't know the answer? Yeah negative camber can be fixed with a camber kit. Takes an extra 10 minutes to install them while installing your springs.
Old Aug 6, 2006
30seconds's Avatar
it's spelt know*** n00b
Old Aug 6, 2006
SLO REX's Avatar
250+ awhp Stage 2
Spelling > tdac69
Old Aug 7, 2006
flipmoderacer02's Avatar
Originally Posted by SLO REX
Spelling > tdac69
but yea, camber kit fixes/reduces the camber of the tires so it doesnt look like this /.. \
Old Aug 7, 2006
Civicman1988's Avatar
you need to get a camber
Old Aug 7, 2006
dj02's Avatar
http://www.7thgencivic.com/forums/sh...d.php?t=133266
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
