Shoud I put these fogs......
Boobies are the mans tinkertoys
well do you have any suggestions?? i have been searching the crap out of sites looking for something i can make work.
if you dont really care for them, could you please give me other ideas cuz i am all out
are those an exact fit or are you guessing? Because if they are an exact fit... i say get them... that will look really cool/unique.
btw... get clear lens instead.
Do a photoshop to compare.
yah i know i really want the oem ones, but i have been asking for people to hook me up with some measurements of the oem fogs to see if they can fit.
they are not exact, but they will be close depending on which ones i get. i have been looking at a few, and those yellows raybrigs are a little to fat, but it would be nothing to take a dremel to it.
yea i think if you smoke them it would look better than the clear ones, a lot better than the yellow ones and yea anything to make them not stand out as much.
you think i will still be able to see with them pretty good, which would make them just for looks and not lighting. i will do some searching into tinting them. i got a lot of extra window tint from my truck...........or i will get the smoked lamin-x film
hahaha oh yeah 1,000 post!!!
uh i would just buy spray tint. the lamin-x traps het causing the film to burn and bulbs to burn faster. if you smoke em a little there will be almost no difference in light output, especially with yellow. fogs ARE mostly for looks. My oem with clear bulb is not visible at all (when i had nokya yellow tho there was a big difference). I guess it depends. try it out and if you don't like it, rub off the tint.
i am also considering putting some projectors, i am picking up a perfectly good set from a local for only 20 bucks
, and i will prolly black them out since they are chrom crap and then i will eventually do a retro with some valeo or bosch. what do yall thionk, then that way still have good stocks for when i sell it and not ruin my stock ones
, and i will prolly black them out since they are chrom crap and then i will eventually do a retro with some valeo or bosch. what do yall thionk, then that way still have good stocks for when i sell it and not ruin my stock ones Thread Starter
yah i think i may try and order them this weekend, cuz i am bidding on a pair of them on ebay and if i lose it then i will order them. they dont fit the whole thing, dependsing on which ones i get, and if they dont fit then i will make a black frame around it that covers the whole hole. and i may recess them some
thanks for the comments guys!
then which ones??
how does it not flow either, those holes are already there so it would just be trimmed to fit a little.
now i am really considering putting these in the upper hose instead of the yellow ones because i picked up a set of projectors for dirt cheap and plan to retro some HIDs with Valoes or Bosch projectors.
they are projector fogs. the color will depend on which brand i get, its either a clear lens, a smoked lens, or yellow lens. the use 894 or 898 bulbs, BUTTTTTT they can also fit D2S with little mod to the base of the bulbs.
they are pretty bight and have a colorful cut off that should match my future HID setup
these are peoples set ups from HIDplanet forums also.
