Ported Throttle Body Installed
Old Nov 25, 2005
I finally got the throttle body back from www.maxbore.com and put it on right away. Well looking at the pic, I saw that the idle adjust screw is useless, since the lever is sitting against the actual throttle body. Also there is no play between the throttle cable lever. Turns out this isn't really a problem as long as the cable has a small amount of play (I set mine to about 1/4inch where I could move it left and right without opening the valve). I also tightened the cruise cable so the black lever for it was also almost touching the throttle lever. Okay VERY IMPORTANT if you do this, make sure you are using the correct throttle body for your car. Auto and manual tranny have DIFFERENT throttle bodies. So if you buy one here, make sure its the same.
Gains: Well at first I had some idle surging problems, but that was fixed after I did the idle learn. It still sticks a tiny bit when the rpms go down after revving, but only for a second. It doesn't affect driving. Overall I would say this is a good mod. It feels like it did when I had the typhoon intake on. There is a tad more power across the rpm band. Since I'm using the stock airbox, I had to trim the rubber mount around the throttle body to accomodate the extra porting. The good news is the intake manifold was already ported larger. So this new throttle body matches the intake mani port exactly. Anyway, here is a pic. You can see how the levers are almost touching.
Old Nov 25, 2005
goodtimes's Avatar
looks nice gear so why dont you put the typhoon intake on and then see how it goes,and then the intake mani should be nice to. how much did you bore it out to.
Old Nov 25, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
^^^long story, airbox is better for idle and low-end, my god gearbox, your car has a lot of stuff to enhance a turbo i cant wait to see the number's you'll put down with a turbo.
Old Nov 25, 2005
well just the tb and exhaust. the head is coming off summertime and so is the header. Oh for the other guy, the intake will be limiting because it has a smaller diameter pipe compared to this tb.
Old Nov 26, 2005
DDragon7's Avatar
I thought your car was dead?
Old Nov 26, 2005
well yea but i can still drive it. just gotta watch the temp gauge and keep adding coolant until I can swap a new head in.
Old Nov 26, 2005
hey do you guys want some installed pics?
Old Nov 26, 2005
Shifty's Avatar
duh.....lol....stop teasin!!!!! post up!!!! you know you want to
Old Nov 26, 2005
mrDFWmechanic's Avatar
you ever plan on going turbo ?
Old Nov 26, 2005
ya in a year or so. i'm already buying parts. but i gotta fix engine first.
Old Nov 26, 2005
Mutha Fn FBM 85's Avatar
Ride BMX
Nice. How much did that cost you?
Old Nov 26, 2005
$105 shipped not bad at all for the gains
Old Nov 26, 2005
booba5185's Avatar
did u have to ship the TB in?
Old Nov 26, 2005
Ride BMX
Not bad at all.
Old Nov 26, 2005
yea i shipped it, then he ports it for 3 days, and sends it back.
Old Jan 4, 2006
Eclectic's Avatar
Eclectic is an unknown quantity at this point
what were the gains and where's the pics?
btw, was it hard to install?
hmm, i checked the maxbore site and they said they only do service and don't provide...so where can you buy a manual throttle body?
Old Jan 4, 2006
well you're supposed to send your own but that means no driving for a week... i'll try and get installed pics up. gains well not very noticable but the gears in my auto are stretched out a bit more so it doesn't shift as early as it used to. I think with a turbo it would be more noticable but still with na you're getting more air in.
Old Jan 12, 2006
Eclectic's Avatar
i'm quoting this from another thread:
simply boring it out will increase the flow capacity of the throttle body... but if you have an intake manifold that doesn't flow much, you can bore out the throttle body all you want, and those extra airflow wont do much.
hence an aftermarket intake manifold may be necessary... although thats another thing that isn't so simple... simply bolting on a higher flowing intake manifold wont necessary yield bolt-on gains too. (as evident by those that have slapped on the KMS intake manifold)
so i was wondering, if you get a bored throttle body, would an aftermarket CAI or short ram be necessary? i was hoping i wouldn't need to because i don't like the added noise and i'm okay with the K&N drop in filter
thanks
Old Jan 12, 2006
they are talking about the intake manifold which is actually the piece under the throttle body. in our case, the intake manifold port is already larger than the stock throttle body. when you get the throttle body ported, it will match the intake manifold perfectly. as far as intakes, yes the metal tube designs like K&N and AEM have a pipe diameter that matches the stock throttle body diameter. so unfortunately these designs will not be as good. thats why i'm trying the weapon-r intake it has a connection tube that goes from 3 inch to 2.5 inch of the throttle body so there is no worry of it not being big enough if that makes sense. or you can keep the stock intake and trim the rubber ring to accomodate the larger tb like i have now. i'll try and get pics but i'm super busy now.
Old Feb 4, 2006
Civicman1988's Avatar
So when i put my throttle body on my stock intake will not fit?
Old Mar 7, 2006
marineman5454's Avatar
marineman5454 is an unknown quantity at this point
i just sent mine out to maxbore and should be getting it back soon how much gain can i expext with just a 2 1/2in aem intake i probly have to go bigger on the intake to feel anything huh?
Old Mar 7, 2006
i definately noticed a difference til the tps broke.
Old Mar 8, 2006
PiNoYxRaCeRxRH's Avatar
PiNoYxRaCeRxRH is an unknown quantity at this point
whats a tps?
Old Mar 8, 2006
throttle position sensor.
Old Mar 8, 2006
I had mine done from maxbore and it was beatiful. took them long enough but it was well worth it.
cukaracha
Jul 7, 2015 05:50 PM
Reverb2005
Jun 26, 2015 06:22 PM
cukaracha
Jun 11, 2015 08:44 AM
mievil
Apr 28, 2015 11:02 PM
