my shocks are blown
Old May 14, 2005
es2k2's Avatar
Proud to be a civic owner
my shocks are blown
Installed tein s tech springs 2/3 weeks ago and my shocks are blown now!!!
Old May 14, 2005
2k1's Avatar
2k1
2k1 is an unknown quantity at this point
damn that was fast!!! how low is the drop?
Old May 14, 2005
eye_see_you's Avatar
let the devil out
my stock shocks blew out quick on my eaibach springs.. but riding on my tokico's now
Old May 14, 2005
Rennen's Avatar
New Mod on the Block
my stock shocks are still good, and i've had my neuspeed sports springs for about 4 months now.
Old May 14, 2005
es2k2's Avatar
only 1.3 in the front, 1.4 in the back...
hate roads in chicago.. they have potholes and bumps everywhere
Old May 14, 2005
hustlelikem0fo's Avatar
should of gotten coilovers.... now you gotta buy new shocks, take everything apart again and redo the job OR pay someone again to take all the stuff off. coilovers like Teins would of been maybe 100 bucks more expensive in the end..
Old May 14, 2005
es2k2's Avatar
^ yah you are right about that... now the money i spent on it could have gotten myself coilovers... i didn't expect the shocks would be blown that soon... i was hoping for like a year...
Old May 14, 2005
how can you tell? ride is really bouncy?
Old May 14, 2005
flipmoderacer02's Avatar
yea, i want to know how you can tell if the shocks are blown cause i am planning on getting s-tech or eibach sport springs and need to see if i should save up for some new shocks as well
Old May 14, 2005
es2k2's Avatar
i heard noise coming from the front suspension and the guy at garage kwai said it sounds like the shocks are blown, 'cause he couldn't find anything wrong with it... but i don't feel that bouncy at all..
Old May 14, 2005
es2k2's Avatar
Or could it be this instead of my shocks are blown???
now i'm very confused...
http://tegger.com/hondafaq/tsb/civic/x01-054e.pdf
http://www.7thgencivic.com/forums/sh...d.php?t=209517
Edit: I do hear the noise when i go over bump but sometimes even when i turn...
Old May 14, 2005
i always hear noises from suspension. I thought it was just springs. If the shocks aren't leaking fluid, they're prolly fine.
Old May 14, 2005
K20EQUIPPED's Avatar
K20EQUIPPED is an unknown quantity at this point
if there is noise coming from the front and the ride is not bouncy it's just your springs...remember lowereing your car means you have taken 2 coils or more out of the area a stock spring would sit, so there is some movement in there...I have noise on my Neuspeed Race and my shocks are fine.
Old May 14, 2005
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
two ways to tell your shocks are blown:
1. the ride is really bouncy, or when the car is parked, and you push down on one of the corners of the car from outside the car seems to bounce a lot more then it did before.
2. theres a huge puddle of the shock fluid under each of the strut towers when you pull out of the parking spot.
#2 is how i found out.
Old May 14, 2005
bamb00's Avatar
i have my tein s tech for over a year now and everything is in great shape, i do hear a little squeaking once in a while but didn't think it has anything to do with the shocks. now that i've read what you guys posted i am even more relieved knowing that my shocks are fine.
Old May 14, 2005
xDCx's Avatar
xDCx will become famous soon enoughxDCx will become famous soon enough
i been ghetto and riding on dropzone coilovers lowered to half a finger gap since january (stock struts/shocks). no problems thank god for flat florida roads
Old May 14, 2005
es2k2's Avatar
hm... ok glad that it's not the shock then...
so the knocking noise i hear when driving over bumps, is it normal? i have the auto shop guy to look at the springs for me this morning and he said everything is ordinary...
i can ignore the noise?
Old May 14, 2005
bamb00's Avatar
maybe it's not the shocks or springs that is causing the problem. try look for loose bolts, do you have aftermarket sway bars or other bars?
Old May 14, 2005
es2k2's Avatar
no aftermarket sway bars or anything like that...
i have firestone to check it for me once when i do the checkup and they said it's from the springs...
Old May 14, 2005
xDCx's Avatar
its the upper mounts. do a search
Old May 14, 2005
technick03's Avatar
technick03 is an unknown quantity at this point
Mine are starting to go too. I've had skunk 2 coilovers for about 2 years now and raised for the winters and slammed about 3 - 3.5 " from spring to fall. Ride was fine. Now my shocks and hitting bottom on every hole/bump, it sux, but what can you do. Salt Lake roads don't help either. Sorry to hear yours went so fast. Time to spend a couple hundred dollars again !
Old May 14, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
THe ride being really bouncy doesn't mean blown shocks... It means they are under stress. When you start hearing clicking and you always hear a loud boom every time you hit a bump... then you can worry.
Old May 14, 2005
read being bouncy could very likely mean blown shocks because they are no longer performing their job and dampening the motion of the springs. due to this, the springs can travel further and for an extended period of time, leading to a bouncy ride.
Old May 15, 2005
2k1's Avatar
2k1
you can always tell if the sturts are blown if there is fuild all over the struts and stuff...i noticed that on my buddys when he had genaric coilovers on his car and it was f*ckin messy as ****
Old May 15, 2005
nigrinij's Avatar
nigrinij is an unknown quantity at this point
Angry Noise in front
Brand new Civic with 1000km on the clock.
Noise in front suspension when you go over a bump
on the road, Please help.
Old May 15, 2005
es2k2's Avatar
now this thread needs to be moved to suspension
Old May 15, 2005
kasimmmmm's Avatar
civic's oem shocks suck. They must must be upgraded even with the slightest drop.
Old May 15, 2005
scatman's Avatar
Still in the game...
i rode on eibach spotlines for around a year and everything was fine.....
push down hard on the front of your car and if it doesnt bounce back up real loosely then ur fine.
Old May 15, 2005
kasimmmmm's Avatar
yes, and it sags...
Old May 15, 2005
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
its probably cause your springs are settled now. ive had my teins for 2 yrs, and my stock shocks are still fine.
