****UPDATED w/ Beam pattern pics*** Cleaned TYC lens *** pix inside***
Old Jan 9, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
Well first off, i had a old set of projectors that i bought off some guy fo 20 bucks, and that they wouldnt work cause the mounting brackets for the lights inside was messed up... so i decided to swap lenses from those into my tycs.... Well they didnt work cause they were to big to swap... So while i had one tyc tore apart i figured i might as well clean it... And man what a difference it made!!!!
The clean lens below....
And the dirty lens...
Can you see the differnce? I still need to take time to clean the other, i just left it like that cause i didnt seperate the housing on that one...
Also, do you think the decal below the headlight looks okay? i kinda liked it at first but now, i dont know
Injen
Old Jan 9, 2005
injencivic's Avatar
and it doest look like that because of the angle of the picture, thats just the best angle i could get without glare... but trust me the drivers side looks like its just a piece of glass in there.
Injen
Old Jan 9, 2005
xX03EXx's Avatar
Sweetest Dude on 7th Gen
i thought the top one was the diry one at first
Old Jan 9, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
It does look a bit cleaner but I cant really tell in those pics.. The decal is alright.. might look cleaner without it! but its fine..
Old Jan 9, 2005
injencivic's Avatar
another picture
Old Jan 9, 2005
Nameless's Avatar
TURTLEonK
I dont think the pics will do it justice
Old Jan 9, 2005
injencivic's Avatar
thats the only decal i have on the car right now... as soon as i get my front window replaced i will put my sponsor decals back on
Injen
Old Jan 9, 2005
injencivic's Avatar
thats the only decal i have on the car right now... as soon as i get my front window replaced i will put my sponsor decals back on...
Let me tell you one thing.... tyc uses shitty putty to seal the headlights, thats why you have to bake them to seperate the housings.... and it doesnt seal them good either.... so i recommend cleaning your lenses and sealing them with liquid nails, which is like bathroom or kitchen silicone but clear...
Injen
Old Jan 9, 2005
injencivic's Avatar
i dont think so either.... most pictures IMO are like that... they sometimes make the car looks worse then it really is...
If you could just see the projector in person you would really see the difference..
Injen
Old Jan 9, 2005
mexinaction's Avatar
i dont really see th difference either
i would say remove decal IMO but hey it is my opion
Old Jan 9, 2005
exclusive_vtec's Avatar
i can see the difference
can u feel it? visably..
Old Jan 10, 2005
injencivic's Avatar
^^^ absolutely i can see a big difference in the light output... That side is sooo much more clearer, crisper/cleaner.... I will post pics of the pattern tonight when i got out
Injen
Old Jan 10, 2005
playa6tnine's Avatar
playa6tnine is an unknown quantity at this point
to me the bottom pic looks like the clean one.
Old Jan 10, 2005
abmerop18's Avatar
Jam out with your clam out.
i cant see the difference. what did you use to clean them? i need to clean mine up
Old Jan 10, 2005
Keet's Avatar
Keet will become famous soon enough
Are you sure you didn't switch the pics around? The only difference I see is the top one looks cleaner, but according to your post I'm wrong.
As for the decal, it could have been more to the left (in pic) cuz then it wouldn't curve downward as much.
Old Jan 10, 2005
injencivic's Avatar
beam pattern pictures...with stock tyc bulbs
Injen
Old Jan 10, 2005
injencivic's Avatar
look at the projector lens, not the headlight housing itself...
Injen
Old Jan 10, 2005
injencivic's Avatar
No, the top projector lens picture is the clean lens.... it looks dirty in that pic cause the housing is dirty on the outside...
injen
Old Jan 10, 2005
injencivic's Avatar
I cleaned the projector lens with just a smooth cloth... I talked to impulse and he said some type of window cleaner would be fine as well, just to make sure it doesnt scratch the projector lens since they can scratch easily...
Injen
Old Jan 10, 2005
NightRider02's Avatar
sleekest 7th gen on the right coast
NightRider02 is an unknown quantity at this point
you should get HID's, and you should get rid of the decal
Old Jan 11, 2005
injencivic's Avatar
all i have to say is, reto-fit this spring!!!
Injen
Old Jan 11, 2005
injencivic's Avatar
all i have to say is, retro-fit this spring!!!
Injen
Old Jan 11, 2005
01blackCVC's Avatar
01blackCVC is an unknown quantity at this point
Pretty sweet... I took my TYCs off recently, but I might go and clean it up and put them back on... Good job bro!
Old Jan 11, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
coolness. i guess i should do this while i have my headlights apart.
