DIY Custom Gauge Faces (03-04 civic coupe)
Old Aug 11, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
aight i read this article on team-integra.net about some guy takin his stock gauge clusters on his GSR, scanning them onto a computer, and inverting them for the black number/white background scheme with the stock-ish look. seemed interesting, decided to give a wack at it...
after a bit of figuring out, heres my first version (second version in the works...) of my custom ghetto-fabuolous gauge faces for 2003-2004 civic coupes.
note: i love the stock gauges, 'cept for the font. that was the main thing i changed with these new ones. i had a pic of the TL and TSX gauges while workin on them.
comments appreciated!
second note: this is just the first version, the black ink in some parts is still not dark enough and the uneven lighting behind the 03-04 gauges makes it look kinda bad at night. eh, ill work on it
ohyeah, the gauge needles dont have the support of the little stem so they rest pointing downwards. they bounce right back up when the ignition is on. needles were also painted red.
ID:	35708   Click image for larger version
Old Aug 11, 2004
Akutenshi's Avatar
The Rizing Sun
looks good. just not bright enough. 10x should be good
Old Aug 11, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
Thats looks real nice. Can you make me some?
Old Aug 11, 2004
skarteez's Avatar
its easy. ill make a DIY if enough people want me to
Old Aug 11, 2004
Silver_JS5's Avatar
Silver_JS5 is an unknown quantity at this point
yeah, a DIY would be sweet....
Old Aug 11, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
Wow, that's cool, how'd you do it? DIY please!
Old Aug 11, 2004
Quijano187's Avatar
The Evil Genius
Make some for me! come on
Old Aug 11, 2004
Arcan3's Avatar
Arcan3 is an unknown quantity at this point
Diy Wanted Here!
W()()t W()()t!!!
Old Aug 11, 2004
spoon's Avatar
anti rice
Very nice work man
Old Aug 11, 2004
civic2uner's Avatar
diy please
Old Aug 11, 2004
civic2uner's Avatar
so are you gonna do a diy?
Old Aug 11, 2004
skarteez's Avatar
aight you guys, heres the DIY
first off, you need to take out your gauge cluster. to remove the bezel, locate and remove the two screws (should be on the upper portion of the bezel). for the gauge cluster, take out the 3 screws (two on each side, one on the top end) and unplug the harness.
then disassemble the cluster by depressing the tabs on the sides to take off the covers and cluster bezels. then CAREFULLY, remove the needles and cluster faces (the tach and fuel/coolant faces have some adhesive. just pry them off).
it should look like this now:
note: stock clusters should have some white LED light diffusers (mine are those orange things cause i had the numbers light up yellow-ish).
after this, take your gauge faces and scan them into your computer. to get over the problem with the little thing sticking out that the needle rests on, you can remove that by depressing the two tab things on the back side.
if you dont got a scanner, do what i did: go to a glass-top table, put a light under it, and trace the gauge faces onto paper.
then you can take THOSE and go to kinkos and scan them there (for convience, you could always scan your faces at kinkos instead of tracing them.)
using a high-end graphics editing proggie (ie adobe photoshop, macromedia fireworks, jasc paintshop pro), add/takeout lines/hashmarks, add/remove misc things, and edit numbers/add numbers to whatever you scanned. this is the fun part because you can just do whatever you want with them. you could try carbonfiber backgrounds, more numbers on the tach, re-do redlines for those of you with valvetrain upgrades/swaps, display in KPHinstead of MPH, add 7thgen logos (i added an SOHC VTEC emblem thingy )
afteryou are finished with that part, print them out on transparencies, have about 4-5 copies of each (ill explain later). whatever is white on the actual image file will be clear on the transparencies and other colors will be what they are.
the reason whyyou want 4-5 copies is so that yo udont get the indiglo kind of look. the light will show right through the black ink print with 1, 2 even 3 copies. also, especially on the fuel/coolant gauge, the little inidcator lights dont have the white LED backlit light coming through, so those are completely black. you want the surrounding backlit light for the hashmarks and needles to not show through the black ink on those parts so it all blends in together.
in this pic, you can see the darker middle and lighter surrounding part. baaaad. the extra layers of black ink will help make everything (backgrounds) look like one light level.
after you have your multiple copies, use your stock gauge faces as templates to determine where to cut around the gauge faces and where the holes are. after that, stack the layers on top of one another, securing them with some tape (invisible doubleside sticky is recommended).
make some cutting adjustments and trim off excess so that they fit good and you are happy with them. then simply place them back into the cluster, assemble it, recalibrate needles and yerrr done!
NOTE: to recalibrate needles, place cluster on flat surface with the bottom edge paralell to your body (without needles assembled). take tach needle, position it so it is pointing STRAIGHT down towards you and insert into hole. same with speedo. for fuel/coolant, maintain cluster position and position needles as if they were pointing at empty and cold (for fuel and coolant gauges respectively). done!
sorry for the lack of pictures, its my first DIY
Old Aug 11, 2004
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
lloks good
Old Aug 11, 2004
civic2uner's Avatar
yes!!!!!
Old Aug 11, 2004
gotti's Avatar
id f*ck it up
Old Aug 11, 2004
cosmo's Avatar
cosmo is an unknown quantity at this point
Wow, how did you get them to be sized prefectly so when you printed them out they were the same size?
Old Aug 11, 2004
sCoTtEh's Avatar
sCoTtEh is an unknown quantity at this point
i like.
Old Aug 11, 2004
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
i'd so screw up and then i'd need another cluster .... awsome job everybody on this site is doin creative **** these days
Old Aug 11, 2004
zachgeyer's Avatar
sweet thanks man
Old Aug 11, 2004
skarteez's Avatar
since i traced them onto 8.5x11 computer paper, the sizes on that paper is perfect sized. after scanning them, make sure your canvas size is set to those dimensions and have kinkos print them out on 8.5x11. no bigger, no smaller.
Old Aug 11, 2004
Hwoody77's Avatar
How long did this whole thing take you?
Old Aug 11, 2004
cosmo's Avatar
Ohhh, that makes sence, alot of sence. Thanks.
Old Aug 11, 2004
skarteez's Avatar
the whole thing dragged on for like 3 days cause i had to keep runnin back to kinkos for extra copies (looots of mistakes)
but the whole editing took me roughly an hour, assembling/dissasemling was tops 20 minutes, cutting/trimming/fitting was 1.5 hours. sitting there lookin at it took the longest: 3 hours all together
Old Aug 12, 2004
Quijano187's Avatar
The Evil Genius
Thats looks great, I'm going to do this as soon a get back from vaction. So your telling me kinkos did all of the printing ? A;; i gotta do is bring my gauges?
Old Aug 12, 2004
skarteez's Avatar
if yyou have another car, bringing your gauges to kinkos to scan/edit would be a good idea. but using their computers could get a bit expensive (44cents a minute). so try using a scanner if youve got one or try and borrow one. or do what i did, trace them. use the light/table thing inthe pictures. then scan them at kinkos (i fyou dont got one at home) then edit it at home, then print them there.
Old Aug 12, 2004
abmerop18's Avatar
Jam out with your clam out.
that looks awesome. good job man
Old Aug 12, 2004
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
to much work from me but relly cool i like it
Old Aug 12, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Woohoo! Looks like Ill be sporting custom SSM gauges with custom fiber optic lighting in no time.
Old Aug 12, 2004
Jai's Avatar
Jai
Jai is an unknown quantity at this point
damn, I'm interested in doing this.. but scared to f_ck it all up lol..
Old Aug 12, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
real nice
