Mods to be installed tomorrow...
college and working sucks but most of us are making it threw and still going all out.. and if u arent in the 13's something is wrong
I made a custom N-tercooler this weekend. DIY style
I bought a used dry NOS kit for $200. Went to HomeDepot and bought a 5' roll of copper tubing for an ice-maker $5. Made a loop with the pipe and drilled extremely small holes using a drill press. I hooked up the N2O switch to my Alch injection switch. When under boost the alch inject and the N2O N-tercooler turn on. I think a small amount of the N2O gets picked up by the air intake as it is pulled through the intercooler After a couple of runs the intercooler was extremely cold to the touch. Under boost it feels like it pulled harder. I live in South Texas were 100 degrees is common in the summers. I am sure it will come in handy during the hot months. I already noticed on a hot day my car does not pull as hard under boost.
After the install my car pulled great. I convinced a friend with an all motor Integra to give me a run. After the run he must have thought that I was spraying into the engine. I took him by at least 3-4 cars. He claims to run low 14's. So I must be in the 13's.
BTW: I am at 11psi on the weekends and 7psi on weekdays.
No problems since I put in the new headgasket and blockguard.
KMS block guard for less than $100, alot of members here say it is ****. but I see it as a little extra insurance on stock internals. My methanol injection- it reduces detonation. Block guards support the top of the cylinder walls from moving under pressure.
i have my battery in my trunk... got the moroso battery tank but they want me to have a visible big as* ugly switch on the outside of my car so they can shut the car off if i crash
damn 10s?
13.99 or faster, u need a snell helmet.
11.99 or faster, full roll cage
battery in trunk, you need a visible switch mounted on the outside of car...
nitrous... need a blow out/dump tube going straight down from the bottle towards the ground, otuside of the car...
Here are my 1/8th mile results running street tires on 17's. I could not launch hard do to wheel spin and had bad 60ft times. But I had to just make up for it with better reaction times. The best run was 9.1 and 9.25. The rest were around 9.3
I guess I will need to get a helmet if I go to a 1/4 mile track. These times were before installing the DIY N-tercooler.
nice numbers...
u using mehtanol or isopropyl? my car runs like crap with isopropyl and i was misfiring like a ****, and fried the plugs
My car ran like crap on Isoprop also. I run pure methanol only. Nothing else touches my car. I think my dyno at 10psi and 220hp proves that methanol works. I think that Catalyst before his PnP head at 8psi was running 186hp. I was also still rich and could have lean it out and gained another 10hp. But I was tunning at a Mustang shop and I have been told richer is safer. I think running rich and using IK24's is a little extra insurance incase the Methanol runs out and I dont know it. Has happened twice already once at 11psi. No problems and the leakless headgasket is holding tight.
I have know there are pros and cons on block guards. I think the good out weights the bad.
I was very pleased with my 8th mile speeds. fastest was 83mph on a couple of runs. I didn't even get traction untill 3rd. So I know I will be smoking in the 1/4.
Originally posted by FuzzBeC00L
13's I dont see maybe 14's even if with the sf kit show me wrong buddie I been drinkin agian
I think future's car is faster than cat's honestly, Cat didn't say much online, but when i was talling to mike stafford... he said cat's 13.6 pull was on slicks, future ran his 13.7 on 19s
Originally posted by C2i0v0i1C
since madwheel showed us his weekend project, i thought id show you all my projects and new toys that came in last week
heck yea man.. hot stuff Joined: Sep 2001
im not switching turbos i was just making it look pretty with all the parts i have laying around, the only parts out of that picture that are going on the car are the rims.
haha damn you!
im waiting on the emanage, too much of it is in japanese lol, but the rest of the stuff is on and running
rims are volk gram lights 57c, the turbo anyone can have for a decent fee, the rims have tires on them now, TOYO PROXES 4.. 205/40/17, and here is another pretty thing
[IMG]
[/IMG]
[IMG]
[/IMG] Originally posted by MadWheel
Cat already pulled a 13.6 and futursxswap pulled a 13.7,
Search and Learn
Originally posted by dober
Future's run was with 19's on the back not the front. I think he had some mismatched 15 inch wheels on there at that time.
19's on rear is right
