Lowering My Car...
Old Jun 22, 2003
CivicBound16's Avatar
CivicBound16 is an unknown quantity at this point
Question Lowering My Car...
If I want to lower my car a/b 1-2"...and want to get an even effect (no height diff in front & rear) I want to use H&R lowering springs...Im not too sure if they are the best but I have seen some of you that have H&R's and I like the way it came out. Is there anything else I will need...tell me becuase I wanna get all of this done @ once! I also plan on gettin 17" Tires and Rims...what order should I do all this in...and if anyone has H&R's how was the ride after...thanx
*I HAVE READ THE FAQ's
Old Jun 23, 2003
CGodwin3103's Avatar
I Am Legend
CGodwin3103 is an unknown quantity at this point
You can get Ground Control coilovers. Stock struts will be fine.. if you go to 2 you should look at a camber kit.. other than than you will be fine.. Maybe if you want a superior setup koni yellows with gc's, or the tien struts/coilover set... and a camber kit should really be looked into for a full 2 inch, or maybe 1.75 drop..
With your car lowered your stock struts will go out a bit sooner, but will be fine...
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bhollie
Sep 22, 2015 11:08 PM
