$300...enough to lower????
Old Apr 30, 2003
gOtRyce's Avatar
gOtRyce is an unknown quantity at this point
do you guys think that 300 bones is enough bread to lower my car on springs with camber....install will prob be me and some of my friends...not sure though
Old Apr 30, 2003
civicvtec1ps's Avatar
Search and Learn
you should be able to buy springs and camber with 300 . ya installation might be the problem though. just remember . after you get springs. eventually you will need new shocks
Old Apr 30, 2003
flotsamm's Avatar
Dont forget about getting an alignment done to.. that'll run 50 bucks or more usually.
Old Apr 30, 2003
robbclark1's Avatar
Retired suspension supermod.
and your shocks will probably go eventually so plan on getting shocks.
Old Apr 30, 2003
BlueBoyCivic's Avatar
"Stage7"
Yup shocks is a very good thing to keep in mind! I need the same thing. Isn't the Konis the only one that is available to? If so...look at about $500 more bro...
Old Apr 30, 2003
robbclark1's Avatar
Just spend the extra money and get a full set up. You don't want to skimp on your suspension. Either get springs with konis or a full coilover kit. I suggest doing it right or not doing it at all. You will probably regret it.
Old Apr 30, 2003
VNlilMAN's Avatar
The Standard One
eh as the people here already said... expect to get new shocks eventually.. this should just be a temporary setup...
i was low on funds, all i got was lowering springs.. no camber kit, no alignment. but then again i was on stock wheels and it was just a 1.75" drop so i didnt care... i was satisfied, $200 to lower a car, what a deal.. but ya its ok for now but you should get shocks later on
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bhollie
Sep 22, 2015 11:08 PM
