Trouble with RSX rear sway bar HELP!
Old Apr 24, 2003
604SPEEDANDSTYLE's Avatar
604SPEEDANDSTYLE is an unknown quantity at this point
Unhappy Trouble with RSX rear sway bar HELP!
hey guys...some guy was sellin me his RSX Rear antisway bar (19mm) for 90 cdn w/bushings so its about 50 US but i was just wondering if i should go ahead and do the upgrade? because rite now i have a 2001 Civic (canadian model) and it has no stock sway bar in the rear...so what do i need to do? ive done searches and all i came up with was installs for 2002 lx and so on....has anybody succesfully done the swap in a 2001 civic LX? i need to know what i need to compleete Operation "handle bettter" hee hee! thanks ppl
Old Apr 24, 2003
robbclark1's Avatar
Retired suspension supermod.
you need an adaptor kit for it. I think neuspeed and progress have adaptor kits for the non-equipped sway bar civics.
Old Apr 24, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
click here and scroll down a little
You need these
52308-S6M-000 HOLDER, R. RR. 1 $3.18
52309-S6M-000 HOLDER, L. RR. 1 $3.18
95701-08018-08 BOLT, FLANGE (8X18) 4 $0.47
You can get it from the website shown in that page or you can go to your local acura dealer and ask for them. It should be the same product #.
Old Apr 24, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
he's got a 2001 LX which has no swaybar and no endlink attachments..you'll either have to get an attachment kit or have some custom attachments made and welded on (which is what i did)
Old Apr 24, 2003
robbclark1's Avatar
yeah he just doesn't need the holders da civic. I mean he could put the bar on the but what is the use with no endlinks. Doesn't neuspeed or progress sell the pieces for that? I know hotchkis makes endlinks or get OEM ones, so why couldn't he get a set of those, with the brackets and have them installed? Grey put the progress bar on his 2001 LX, so why couldn't this guy?
Old Apr 24, 2003
ohmysac's Avatar
progress has a u-bolt looking thing for the endlink mounts...but i think its expensive...even more expensive than the swaybar itself
Old Apr 24, 2003
dacivic's Avatar
oh I didn't know. I thought he would only need the holder. Thanks for clear that up =)
Old Apr 24, 2003
OMg so how much are these endlinks? and things go for? so do u think i should go ahead and get the sway-bar ?
Old Apr 24, 2003
ohmysac's Avatar
well the cheapest way to go is get both endlinks, bar, bushing holders, and bushings...and get someone to fabricate some mounts...i went to my local dealer and crawled under an ex just to see what the endlink attachments (brackets...whatever u wanna call them) look like..they are on the lower control arm...easy to see...
anyways...i had my uncle who builds custom trailers make me a set and weld them on for me out of a piece of 1/8th inch box mild steel and they worked beautifully
Old Apr 24, 2003
robbclark1's Avatar
you should start sellin those bad boys then!!!
Old Apr 24, 2003
Bellz's Avatar
Last time I talked to them, both Greg and Rob at Hondawerx and Tornactive both stocked the Progress mounting kits and the rsx bars. Give them a hollar and they can take care of you.
The mounting kit isn't cheap, but it's the easiest and quickest route to getting it mounted. They go for, roughly, $135-140 US for the kit from the above dealers. I'm looking to buy one soon myself.
Old Apr 27, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
so i guess i have to drill some holes under my car (2001 civic LX sedan) to install the brackets, bushings, endlinks and the bar....damn
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
Nalmonte
Jul 22, 2015 09:08 AM
fordover
Jul 11, 2015 09:10 PM
