Anyone with neuspeed sports.
Old Apr 24, 2003
DXPOWER's Avatar
DXPOWER is an unknown quantity at this point
Appearently I have lowered my coupe with Neuspeed sport sedan springs. I've been told to cut one dead coil off of the back springs. I am almost convinced to do so, but i'm worried that the front will be higher than the back after I do it. Does anyone have pictures of a car that has had one coil cut from the rear neuspeed sport springs? or does anyone know how much the ride hieght is affected by doing this. Thanks for any help.
Old Apr 25, 2003
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
if I was you, I'd go with Neuspeed Race. It looks just perfect for coupes. But most likely, if you do cut off one coil, it will even out. I can't say for sure since I haven't done it, but I do have Neuspeed Sports. It took about 6 months for mine to fully settle in.
Old Apr 25, 2003
DXPOWER's Avatar
The problem I have is that I have the sedan springs on a coupe. I've
been told that when neuspeed sports first came out the made them the same for the coupe and sedan. The *** end of my car is too high. I don't think coupes have the weight in the back to settle these springs like a sedan would. Plus I'm trying to get my car right with minimal funds. Just can't afford new springs right now. Nice car by the way.
Old Apr 26, 2003
NytRyder2k2's Avatar
Bay Area
DXPOWER, i know several people that have the same problem as you and got stuck with the sedan springs for a coupe. One of them ended up cutting 1 dead coil in the rear and it came out perfect. Just make sure u dont cut more than 1 coil or else the front will be higher than the rear. he said it rides fine.
Old Apr 26, 2003
VNlilMAN's Avatar
The Standard One
yup i was one of those people..
called up neuspeed and they said they would replace it for free. i went to their headquarters and the got rears "replaced". i'm almost sure they just cut a dead coil. there is nothing wrong with it. the coils are only there to help keep the springs aligned when you jack up the car. i had like 3 finger gap in the rear with the sedan springs, now i only have 1.
Old Apr 26, 2003
my2k1vic's Avatar
my2k1vic is an unknown quantity at this point
i had the same problem, just cut one coil, you will be fine. the rear evens out with front when you do this.
Old Apr 27, 2003
DXPOWER's Avatar
Ok, Thanks for the reassurance guys. Lets hope i don't destroy my car in the process.
Old Apr 29, 2003
VNlilMAN's Avatar
The Standard One
tell us how it goes...
Old Apr 30, 2003
Nodnero's Avatar
Im pretty sure you cant destroy ur car by cutting a coil off ur springs, but hey, Ive been wrong before. Good luck!
Old Apr 30, 2003
VNlilMAN's Avatar
The Standard One
once again its a DEAD COIL, something you dont NEED. has no effect what so ever on spring rate so the ride will still stay the same. well other then the fact that your putting slightly more stress on your shocks since the car is lower.
Rogelio Rey
May 24, 2015 08:30 PM
brodie_rider
Apr 13, 2002 05:01 PM
ChEe12iO
Apr 2, 2002 08:49 PM
Civic2k2RacerX
Mar 31, 2002 01:26 PM
VanDizKo
Feb 17, 2002 05:19 PM
