Girl needing car help!
Rep Power: 0 Girl needing car help!
Just had my Progress rear sway bar installed and now my exhaust tube (Thermal R & D exhaust) is vibrating on the sway bar! It sounds like crap and I am not sure if I could get any type of welding done to help this- ANYONE who has had this problem or any suggestions, I really do not want to take it off, it really helps w/ my suspension
Rep Power: 351 i would go to a shop and have them move the piping somehow (bending it slighty after heating it or something. The other wasy are cheaper but ghetto, IMO i dont do the ghetto route
The Standard One
1 Post
Rep Power: 394 i say whatever works . putting something to stop the rattle isnt going to hurt the car or anything, its just going to save you time/money so why not..
Rep Power: 295 Here's my solution w/ the RSX sway bar and Thermal R&D rear section:
Exhaust + RSX Sway Bar Rubbing - My Solution
Rep Power: 0 Mig the reason is when your car is cold the pipe is probably touching the bar ... when it gets warmed up ... the heat causes the pipe to expand ... changing its path and makes it not touch the car.
This is similar to the TSB for the 2001 civics with the "b" pipe in the exhaust rattling against the frame. It happened when people would drive and hit a puddle ... The rapid compression of the pipe caused by the cold water hitting the hot pipe, made the pipe touch the frame which caused a huge rattling sound.
I bet if you did the same, your exhaust would rattle again.
L8tr
L8tr
