lowering springs vs coil overs
Old Apr 9, 2003
2fst4u's Avatar
2fst4u is an unknown quantity at this point
whats everyone idea on springs vs coilovers
i have lowering springs on my ride, and was thinking
of switching to coilovers, whats the verdict here?
Old Apr 9, 2003
robbclark1's Avatar
Retired suspension supermod.
It depends. Do you want a suspension setup that you can adjust? Don't get sleeved coilovers, but true coilovers. Coilovers sometimes can give a little harsher ride than aftermarket springs and shocks. It depends on what you want. I personally am going for shocks and springs when they come out. I don't want to have to deal with adjusting coilovers and getting an alignment when you do. That is my preference tho. I can see how true coilovers are good.
Old Apr 11, 2003
VNlilMAN's Avatar
The Standard One
lowering spring: set height, cheap, better ride then sleeved coilovers.
sleeved coilovers: adjustable height. not as cheap as lowering springs but still much cheaper then true coilovers. tend to have a worser ride then lowering springs
true coilovers: adjustable height(sometimes adjustable damper/spring rate). usually very expensive. very good ride.
Old Apr 15, 2003
raysz
Guest
Posts: n/a
I originally had eibach sportlines on my ex coupe- rode good everyway, looked too high IMO. Now I have GC coilovers-rides ok on smooth roads(freeway), bumpy on uneven roads(potholes, most streets). But looks sic because its now slammed. All 4 wheels tucked in fender about 1/4 ". BTW, I also cut the lower front strut perch off to get that low. Rear wheels have -3 degrees camber(need camber kit), Front is -1.1 degrees(ok, I think). THe GC's handle alot better.
Old Apr 15, 2003
2k1sscivic's Avatar
2k1sscivic is an unknown quantity at this point
What is a good shock to go with the lowering springs? or are the factory shocks the only ones available?
Old Apr 15, 2003
Weaponx12o's Avatar
koni's are the only ones out so far. tokicos are coming out soon
Old Apr 15, 2003
RedDragon333's Avatar
Konis are the only ones out and the stock ones wont last but a few months
Old Apr 15, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
For me since I autocross I'd rather stick with springs/aftermarket shock setup. It requires less maintenance and is cheaper if you add in alignment for each time you raise or lower the car. I stick with 1 height and get it aligned and boom you got a good setup. That's my opinion since I used to contemplating goin with the coilover setup. Also it rains quite a bit in my area so cleaning and greasing the threaded part of the coilovers from rust doesn't sound fun to me
Old Sep 12, 2005
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
Coilovers all the way
Tein Superstreet Coilvers here
Old Sep 12, 2005
robbclark1's Avatar
this thread is 2 years old! don't bring back old threads
vtec_concept
May 24, 2015 10:27 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
duyaknow
Nov 23, 2001 07:28 PM
CIVICINJEN
Nov 16, 2001 11:44 AM
CIVICINJEN
Nov 16, 2001 09:42 AM
