Do It Yourself Spring Install - Detailed Info & Pics
Thanks for the Help. My buddy helped me install my springs this weekend, it went real smooth. Tookabout 2.5hrs. start to finish with impact gun and all proper tools. He's a mechanic and was very impressed with your instructions.
Props.
Props.
Great DIY man, but one question. I did all of those same steps but when I took that bolt out from the bottom of my rear ones,the whole assembly popped straight down, I'm assuming from the spring. It kinda wedged itself and I didnt know how to get it out. Is that normal? And how do I handle it?
i searched the thread and didn't see that anyone had posted it, but you can get spring compressors for FREE from Auto Zone. you pay a deposit and get it back fully when you return them. maybe this could be added to the first page so people don't chance getting hurt taking these apart.
Fawking Awesome!
I just found this little gem because it's been a while since I have messed with the suspension on my car and needed a little refresher! Got all my tools and ready to tear it up tomorrow. Thanks to the Original Poster and anyone who gave good advice!
Re: Do It Yourself Spring Install - Detailed Info & Pics
i have skunk 2 coilovers on tokico blues. but i found out that i needed that factory bearing ( metal ring ) for the 02-03 models right? thats why it makes all those clinking noises. but i got koni yellows and gc now just sitting in my room. do you know where i could find that part???? that factory bearing for the 2003 coupe civic.
i have coil over sleeves as well, but it came with all these parts and i dont know where they go. Theres a bunch of rubber rings, wider rubber rings, and little screws, if anyone could help me as to where these things go it would be great.
Tyler. Tx
Macpatty
Tyler. Tx
Macpatty
this is an example I made long ago showing the bearing changes between the 2001-2002+ models: http://www.gametrax.net/b+g/
i am seeing only red x's instead of pictures. is there anyway you can update the pics?
bump! im having trouble getting the nut off the top of the strut. using an allen key and wrench but it wont budge! any ideas?
this example was great bruv....i need to know something from you before going to the workshop, drive a civic 1999 DX my engine oil gets low always and the car has good mileage. and tell me something to boost the performance with like cheap but good .
daran
daran
https://www.civicforums.com/forums/p...931-post8.html
