Swaying rear! Please help
Old Apr 7, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
I just got the progress springs and no camber kit. The front of the car is fine, but the back wheels have negative camber for sure. Every time I hit a bump, the back seems to sway side to side. If I hit only with one side of the car, it sways even more. I have 205/17/40's all around, and I dont know what to do. If I get a camber kit, wont I rub, I see that the wheels dont rub because of the camber ( I think). What should I do?
Old Apr 7, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I think you should get a rear camber kit. You might want to check your spring install too. It's kinda hard to diagnose w/o more details.
Old Apr 7, 2003
djmota's Avatar
get rear camber kits and get your car aligned. You will notice a big difference in handling for the better. With those tires you should have no rubbing problems.
Old Apr 7, 2003
bublik's Avatar
Truehonda.com
Well, when I lowered my car, I never got it aligned bc it drove perfectly straight. So you think a camber kit will help. Will just an alignment help?
Old Apr 7, 2003
reytito's Avatar
sorry if this is a tad off topic, but bublik...do you like your ride on the progress, other than the swaying? and also...does the drop look pretty even to you?
Old Apr 7, 2003
bublik's Avatar
Truehonda.com
The drop is about an inch lower or 2 fingers lower in back than in front. So front has 2 finger gap and depending on weather, back has 1 to no finger gap. May look goofy on pictures but looks awsome in real life. The ride is better on sportlines, but if you wanna go low, get the progress, it is actually stiffer and higher spring rate. Good as hell on turns. Trust me, if you live in suburbs like me and dont experience many holes, get the progress. If you live elsewere, sportlines are the choice. Look at my picture under my username.
Old Apr 8, 2003
reytito's Avatar
so it looks better in real life? im' gettin my progress' installed tomorrow. i guess i just don't want a goofy lookin drop. also, what struts are you riding on? stock?
Old Apr 8, 2003
robbclark1's Avatar
Retired suspension supermod.
One you should get a camber kit. The camber won't affect your alignment, but it is a rule of thumb to get your car aligned when you lower or when you change the settings on your coilovers. If you camber is highly negative, get a camber kit and that will fix it. Remember not to set it completely to zero, you do want a little bit of negative camber in the rear.
Progress springs lower alot, and you stocks shocks won't last long, especially if you drive in the city.
Old Apr 8, 2003
civicvtec1ps's Avatar
Search and Learn
get rear camber kit
i think i need one myself too.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
Viczhou
Sep 2, 2015 07:55 PM
