do 7th gens need new sway bars?
Old Mar 7, 2003
digi's Avatar
digi is an unknown quantity at this point
I was wondering if theres a big advantage with new sway bars on a 7th gen?
if so, name a few perks , thanks
Old Mar 7, 2003
VNlilMAN's Avatar
The Standard One
you'll see a much bigger improvement with a wheel/tire and spring/shock upgrade then with a sway bar upgrade
Old Mar 7, 2003
Weaponx12o's Avatar
you dont really need a sway bar, not unless a spring and shock upgrade isnt enough for you.
Old Mar 7, 2003
Zzyzx's Avatar
Autocross Junky
For every thing you ever wanted to know about anti-Rollbars go Here
But if you dont want to read, here is a simplified version.
Anti roll bars perform 2 main functions.
1. Reduce body roll. Springs also reduce body roll, so an anti-roll bar is just a supliment here.
2. Adjust Roll couple distrobution (easily the most important of the two). what the heck is Roll couple distrobution? It is simply the balance of weight distributed between the front and rear tires of your car durring a turn. Springs do this as well, but un like springs adding a Stiffer Anti-Rollbar only affects ride quality a little.
Old Mar 7, 2003
digi's Avatar
thanks for the info
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
Nalmonte
Sep 28, 2015 01:10 PM
Viczhou
Sep 2, 2015 07:55 PM
