Freakin Squeakin Creakin Sway Bar
Just installed 19mm RSX sway bar, with 19mm bushings and new holders. The handling improvment is great, the car is much more eager to take corners now, but..... it keeps squeakin and creakin...... Just driving in a straight line it creaks, I drove a few times over a speed bump, equal bump on both rear wheels, it creaked.... so I think its just the bar rotating in the bushings and nothing to do with the bar twisting or the end-links. I used some Valvoline sythetic grease, but is it possible that I used too much or not enough or the wrong kind? I didn't notice grease on the stock bushings.
You sure it is installed correctly? I installed mine upside down and it was hitting my control arms. Mine doesn't creak and I didn't use grease.
Raiool
Oct 1, 2015 10:42 AM
beanhead
Sep 24, 2015 12:04 PM
