what the hell is this noise?!
Old Feb 25, 2003
Weaponx12o's Avatar
theres this squeaking noise coming from my rear left side. it sounds like rubber rubbing against something. i have my car lowered 2.25" and i checked if the tires might be rubbing against the fender and fender wall but its not. i also tried pushing my car down but it didnt make the noise. it's really annoying [IMG]i/expressions/face-icon-small-mad.gif[/IMG] and i dont know exactly what it is. it squeaks with even the smallest bumps. this started happening all of a sudden a couple days ago after i left my car outside in the cold for the night. my friend says that it might be chassis flex, but i can only hear it from the left side so i dont know. does anyone know what might be wrong? and should i be worried about it? thanks
Old Feb 25, 2003
robbclark1's Avatar
Retired suspension supermod.
did your shop make sure all the bearings and bushings were greased properly? You might also want to check your stock bushings around your control arm to make sure they are greased properly. you can try to upgrade your rubber bushings to poly, that might help.
cukaracha
Aug 29, 2015 05:27 PM
ex2peria10
Aug 27, 2015 09:02 PM
WaryDriver
Aug 22, 2015 06:50 PM
JetsterDajet
Aug 15, 2015 08:07 AM
15EXCoupe
Jul 30, 2015 12:59 PM
