For those of you with the RSX sway bar conversion
Old Feb 14, 2003
iamboo's Avatar
Retired - SoCal FI Mod
Read
Old Feb 14, 2003
Grey's Avatar
DIY King
Actually, people with the 19mm (RSX) sway bar didn't have this problem. Their end-links hold up just fine under all conditions as they should since Honda (Acura) designed them to work with the 19mm sway bar. Now, I only heard of the end-links breaking in an RSX with a 22mm rear sway bar under severe repeated cornering in an autocross event.
Old Feb 14, 2003
djmota's Avatar
title should read" for those with the 22mm progress conversion".
I read that thread last nite Good info for those progress owners.
Old Feb 14, 2003
civicvtec1ps's Avatar
Search and Learn
just bought 19mm rsx sway bar
shouldnt be any problem
Old Feb 14, 2003
VNlilMAN's Avatar
The Standard One
isnt that why progress 22mm comes with a tie bar..
Old Feb 14, 2003
Grey's Avatar
DIY King
Well, the tie bar just stiffens the chassis so there's less chance of buckling. The end-links are still the stock with the Progress 22mm rear sway bar upgrade. That is unless you do what I did. [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Buy a Progress mounting kit. I had to do that since I have an LX, but I'm glad that I did. No way are my end-links going to break now.
Old Feb 14, 2003
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Quote
[hr]Originally posted by: Grey
Actually, people with the 19mm (RSX) sway bar didn't have this problem. Their end-links hold up just fine under all conditions as they should since Honda (Acura) designed them to work with the 19mm sway bar. Now, I only heard of the end-links breaking in an RSX with a 22mm rear sway bar under severe repeated cornering in an autocross event.[hr]
It is either gonna be the end-links or the subframe that'll go. Very common in autocrossing events. I'm sure that relates to my recent thread here about the subframe tearing from a 22mm bar.
Old Feb 15, 2003
artychris's Avatar
artychris is an unknown quantity at this point
I've had my 19mm RSX sways on for many months without a lower tie bar and stock endlinks. I think I'm fine for now. If I ever wish to step up, I'll defintely look into the Hotchkiss 25.4mm rear sway and endlinks...
Old Feb 17, 2003
SoNiCcIvIc's Avatar
Quote
[hr]Originally posted by: artychris
I've had my 19mm RSX sways on for many months without a lower tie bar and stock endlinks. I think I'm fine for now. If I ever wish to step up, I'll defintely look into the Hotchkiss 25.4mm rear sway and endlinks... [hr]
Save your money... 19mm is in the safe zone, it's 21+mm that can cause damage.
Old Mar 1, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
sorry for asking dumb questions, ok the 19mm sway bar off an rsx will fit our cars with no prob at all right? i dont need to buy anthing extrta to make it fit or anything?? and also how much is it? and is it easy to install, and does it help out a lot in suspension, im interested in buying it, thanks
Old Mar 1, 2003
CapYoda's Avatar
Escaped Convict
there's plenty of DIY if you search for it again in the suspension forum. make sure u select "archieved messages" because these are things done long ago.
bolts right on 01 EX; 02+ LX, EX, HX...
if you dont have any one of those.. you'll need an endlink mounting kit... either get it done at a shop or get a custom one from Progress.
all u really need is a 14, 12mm socket wrench/wrench... and an allen wrench...
Old Mar 1, 2003
i checked on hondawerx.com and they only have 22mm progress anti-sway bars but i didnt see the rsx 19mm one, how much is it and i think i read on another thread that if u didnt drop ur car and u add a stronger sway bar, then it could promote oversteer becasue the center of gravity or something is not balanced? can somebody plz clarify thanks
Old Mar 1, 2003
iamboo's Avatar
ask people on clubrsx.com they'll probably give one to you for like 60 bux
Old Mar 1, 2003
Search and Learn
Quote
[hr]Originally posted by: iamboo
ask people on clubrsx.com they'll probably give one to you for like 60 bux[hr]
i paid mine for 60 shippped
used but good condition
Old Mar 1, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
Quote
[hr]Originally posted by: Civic2k1racer
i checked on hondawerx.com and they only have 22mm progress anti-sway bars but i didnt see the rsx 19mm one, how much is it and i think i read on another thread that if u didnt drop ur car and u add a stronger sway bar, then it could promote oversteer becasue the center of gravity or something is not balanced? can somebody plz clarify thanks[hr]
I ordered mine from acuraautomotiveparts.org
Here are the correct part numbers when ordering:
35902 - SPRING, RR. (19MM) (need 1)
35948 - BUSH (19MM) (need 2)
35958 - HOLDER, R. RR. (need 1)
35971 - HOLDER, L. RR. (need 1)
Total cost for those parts is $78.37 plus shipping, which was $10 for me.
As far as oversteer, the 19mm really balances out the car by lessening the understeer, but oversteer really isn't a problem. BTW all my other suspension is stock.
Old Mar 1, 2003
thanks
Old Mar 1, 2003
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
a local Acura dealer will overnight the part for you for $90 + tax
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
beanhead
Sep 24, 2015 12:04 PM
Viczhou
Sep 2, 2015 07:55 PM
