Question for ground control
Old Jan 21, 2003
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
What 's the part number for the ground control?..
and two of the spring is longer and two of them is shorter..
also the adapter which is for the adjusting the height has is
two shorter and two longer..i was wondering how do they match..
thanks...i dont' have the instruction that's why i don't know
thanks..
Old Jan 21, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
hey 1028, have you got your GC's installed?
where did you pick them up ar?...... do you know how the ride is like?
thanks man.
Old Jan 21, 2003
1028CiViC's Avatar
i haven't install it yet....but i will install them really soon..like tomolo or sth..i'll let u know once i have install them......
Old Jan 21, 2003
0100010's Avatar
0100010 is an unknown quantity at this point
From memory, the longest sleeves and spring go up front, the shorter sleeves and springs go on the back (at least on my Sedan, its that way).
Old Jan 21, 2003
DizWikedCivic's Avatar
i have skunks2 and i dont know if the same or different, the short spring are in the front and longer springs in the rear.
Old Jan 21, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
Quote
[hr]Originally posted by: 1028CiViC
thanks..[hr]
Got this off of the Gc Box, it says
GC1505466- Are the front springs
GC1256475-Are rear springs
It says the number on the springs...
Old Jan 22, 2003
1028CiViC's Avatar
Quote
[hr]Originally posted by: XTREME2K2CIVIC
Quote
thanks..[hr]
It says the number on the springs...[hr]
ok thanks but also wat's about the long sleeve and the short sleeve?
which one go in the front and which one go in the back?
Old Jan 22, 2003
1028CiViC's Avatar
also their is 4 upper spring seats (2 front, 2 rear)
wat if i am missing 2 of them.... is it still possible i can install them?
other stuff like the rubber sleeves are their....
because i brought a use set and would like to install them..
just want to know if this is possible thanks.....
Old Jan 22, 2003
1028CiViC's Avatar
Also when purchasing it brand new ground control..can anyone tell me
what exactly comes wif it... because i just purchase a used set..~
Old Jan 22, 2003
djmota's Avatar
ok look on the inside of the sleeves the ones with the BIGGEST notch on the inside are the rears. Since I just happened to be installing my front koni shocks right now I will give you the measurements on the fronts the front spring is a little less than 6" the sleeve is about 41/2" tall. In the front you should have an aluminum upper spring seat a rubber o ring which keeps things from rattling. the rear should have an upper urethane spring seat/insert and a urethane sleeve that is split.. I think that is it i'm going by memory on the rear stuff. hope this helps
SugarRay
Dec 6, 2001 05:17 PM
my2k1vic
Nov 29, 2001 10:29 PM
1028CiViC
Nov 27, 2001 02:45 PM
1028CiViC
Nov 24, 2001 02:14 PM
TOOLOWCIVIC
Nov 18, 2001 10:17 AM
