adjusting ground controls
Old Jan 12, 2003
Gabe's Avatar
Gabe is an unknown quantity at this point
Ok I have had these for a while but never adjusted the front springs. The back are easy but the front are hard to reach.
Just wondering if anyone has any secrets to doing this. Thanks for any help.
Old Jan 13, 2003
VNlilMAN's Avatar
The Standard One
i'm assuming your jacking up the car and taking off the wheel first.. if you arent thats what you should do...
if your are, then thats why they recommend you cut the front lower perch, so that you can adjust it easier..
Old Jan 13, 2003
Gabe's Avatar
well of course im taking the wheel off, but that damn perch is in the way. Plus i set it really low so its harder to reach it . Ok well thanks , I guess i will give it a try.
Gabe
Old Jan 13, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
I just put on my Ground Controls this weekend and I guess since mine is only dropped around two inches it is easier for me to reach the retaining screw.. I had no problem adjusting mine with the tire still on and that is because I didnt cut the perch off..
Old Jan 13, 2003
VNlilMAN's Avatar
The Standard One
uhm.. for the guy above.. how is it easier to adjust the ground controls when you havnt cut the perch off?
you cut the perch off so that it wont get in the way and it's easier to adjust.
Old Jan 13, 2003
Reppin Stage 7
Vnlilman - You misunderstood me I meant to me it was pretty easy to adjust the struts eventhough I didnt cut the perch's off. But I could see how much easier it would be if I had but I think they will be ok the way they are for me anyway...
Old Jan 14, 2003
DizWikedCivic's Avatar
what the easiest way to cut the low spring perch, some people suggest using a hacksaw but that going to be bitch to cut off with a hacksaw
Old Jan 14, 2003
VNlilMAN's Avatar
The Standard One
my badd... ya thats what i thought you meant to say but the wording threw me off "I had no problem adjusting mine with the tire still on and that is because I didnt cut the perch off.. "
ya i have no idea how they expect you to cut the perch.. cutting metal doesnt sound too easy to me... especially when your cutting in a circle and not straight..
Old Jan 14, 2003
djmota's Avatar
air tools is the only way to go and get a decent cut. die grinder with a cutoff wheel
It still looks like a b*tch that perch is kinda thick
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
Jul 12, 2015 11:54 AM
