Ground Control Squeek Rear (already searched)
Old Jan 12, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
I just installed my Ground Control Coilovers and I absolutely love the way it looks.. But I am having a little problem with them and was hoping someone could help me out.. I read the post about the pvc shower mat for the front but I have an anoying squeek coming out of the rear... It sound kind of like rubber or something rubbing somewhere... Just wondering if anyone had the problem and if anyone knows how to get rid of that sound... Thanks [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 12, 2003
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
is the ride bad though?once u install it made that squeek rear
Old Jan 12, 2003
SkiLLzSter's Avatar
illest ma f*cken member
mines did that since the day i got it...and now still does...been a year and half already...
Old Jan 12, 2003
1028CiViC's Avatar
Quote
[hr]Originally posted by: SkiLLzSter
mines did that since the day i got it...and now still does...been a year and half already...[hr]
how much did u lower it?
Old Jan 13, 2003
Reppin Stage 7
I lowered it around two inches all the way around. I have a finger gap all the way around.. The squeeking noise is really nasty but other than that I real happy with the Ground Controls...The adjustability is extremely easy and the install wasnt that hard either... I love 'em but I really hate the damn noise the rears make...Someone help please..!!!!![IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 13, 2003
0100010's Avatar
0100010 is an unknown quantity at this point
Get some really viscous grease, grease up the inside/outside of the urethane sleeve, and the squeeking will go away. Don't use WD40 or anything like that, but get some axle grease or white lithium grease.
Old Jan 13, 2003
1028CiViC's Avatar
how easy to the adjusting?
Old Jan 13, 2003
Reppin Stage 7
It is rather easy to adjust. For me I didnt have to take off the wheel to adjust them but thats only because I have wide thin spokes and could put my hand through there... Thanks for the grease idea I was thinking there had to be something like that I could good.. Thanks Again
Old Jan 13, 2003
djmota's Avatar
is it both sides that squeak on just one ?
Old Jan 13, 2003
Reppin Stage 7
Hey DJ I see you live in San Marcos.. Not to sound dumb but its San Marcos Tx right... If so your about 4 hours from me. I was thinking of attending the Houston meet in Feb. you or anyone in SA willing to make the trip... The more the better...Any way yesterday it was only the passangers side but now the other side is starting to do the same thing also...
Old Jan 13, 2003
djmota's Avatar
nah man its san marcos california. lift up the car in the rear and make sure everything is sitting correctly the spring is centered and the rubber collar thing on top is sitting in the spring. let the car down and make sure everything is lined up.
if that doesn't fix it I don't know. It might be the bushings in the upper arm getting used to being lowered. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 13, 2003
Reppin Stage 7
Quote
[hr]Originally posted by: 0100010
Get some really viscous grease, grease up the inside/outside of the urethane sleeve, and the squeeking will go away. Don't use WD40 or anything like that, but get some axle grease or white lithium grease.[hr]
Just took of the rear struts and lubed everything up, so far so good, I'll wait a couple of days and see how it works out....
Old Jan 14, 2003
DizWikedCivic's Avatar
i dont have gc coil but i have skunk2 coil my dont squeak in the rear but it squeak in the front, just let the springs settle and if they still squeak, inspect the shocks and struts again
Old Jan 14, 2003
0100010's Avatar
You may have to put some lube on the top urethane perch as well, but not very much.
Old Jan 14, 2003
Reppin Stage 7
Yeah I took of the rear assembly yesterday and greased up anything that was making contact and I havent heard a squeek yet (cross my fingers).. Thanks for all the replies you all were more than helpful..
Old Jan 15, 2003
TOOLOWCIVIC's Avatar
I have Ground Control and my front drivers sides makes a poppin noise every time I hit a bump. I've had them for about a year now. I hate that damn noise and its only in the front drivers side.
Old Jan 17, 2003
0100010's Avatar
Is the GC sleeve sitting 'level' on the perch(when the weight of the car is on the spring)?
Do you have a urethane spacer sleeve inside the GC sleeve between the stock strut housing?
Is the bolt holding the Koni on the bottom of the stock strut housing tight(they come loose occasionally, as the threads are a large helical width, I added extra lock washers to mine)?
Do you have camber bolts up front(that side is tight)?
Umm, you might try jacking up that corner, and hand turning the spring about 90 degrees on axis. Test drive it afterwards, see if it still makes that noise. This sometimes works cause of where the 'end' of the spring sits in relation to the motion of the perch/strut. Changing this location, might resolve the noise.
Old Feb 5, 2003
1028CiViC's Avatar
Quote
[hr]Originally posted by: TOOLOWCIVIC
I have Ground Control and my front drivers sides makes a poppin noise every time I hit a bump. I've had them for about a year now. I hate that damn noise and its only in the front drivers side.[hr]
my rear are like that.... i think it's because the shocks blown..
if they are blown already...is it ok if i put it low? since they are blown..
Old Feb 27, 2003
CivicFerio's Avatar
CivicFerio is an unknown quantity at this point
i had the same exact problem.. you know what i did? i simply removed my strut and tried to look at it and when i put it back the sound was gone... hehe.. i also thught about greasing it but it didn't work so i removed it... maybe it was the way i installed it at the first time...
Old Feb 27, 2003
Elite's Avatar
Elite is an unknown quantity at this point
can you guys post a pic of how your front struts and shocks look cuz i lowered my car all the way with gc and i have 2 finger gap in the front and I hate it I think I installed it wrong or something I need a good pic of how you guys did it.thanks
Old Feb 27, 2003
BJAI's Avatar
BJAI is an unknown quantity at this point
Quote
[hr]Originally posted by: Elite
can you guys post a pic of how your front struts and shocks look cuz i lowered my car all the way with gc and i have 2 finger gap in the front and I hate it I think I installed it wrong or something I need a good pic of how you guys did it.thanks[hr]
ya i am having the same problem...ya i might get a picture up soon.
Old Mar 4, 2003
Elite's Avatar
go post some pics.[IMG]i/expressions/face-icon-small-tongue.gif[/IMG] before I buy neuspeed race springs.
Old Mar 5, 2003
BJAI's Avatar
Quote
go post some pics.[IMG]i/expressions/face-icon-small-tongue.gif[/IMG] before I buy neuspeed race springs. [hr]
i was using neuspeed race before...well i find it not low enough...at least the gap were
really bad..when i had 195/15/55
Old Mar 29, 2003
philsep36's Avatar
philsep36 is an unknown quantity at this point
i to have that popping problem in the front. last summer i never had a problem with it. but when i put my rims back on the noise is horrible! i am goin to try what ya'll have been tryin today. this is a must fix cause it is drivin me mad!
Old Mar 30, 2003
raysz
Guest
Posts: n/a
My rear GC coilovers also started making noise after driving through a dirt lot. All I did was grease the upper urethane perch and installed a plastic washer between spring and lower perch. I made it with the plastic lids that come on coffee cans. Noise is eliminated
SugarRay
Dec 6, 2001 05:17 PM
my2k1vic
Nov 29, 2001 10:29 PM
1028CiViC
Nov 27, 2001 02:45 PM
1028CiViC
Nov 24, 2001 02:14 PM
TOOLOWCIVIC
Nov 18, 2001 10:17 AM
