Ebay Bars...Any good?
I personally hate the steering feel and response in our cars but I dont have the money to throw at it right now to go big bucks on suspension improvements. I've seen the strut tower bars on ebay and I was wondering if anyone here has them and if they make any difference. Thanks a lot .
Escaped Convict
IMO they stiffen up the chassis to some degree.. they work, they aren't design for specific vehicles.. not much R&D goes into it.. but they work.
and they're cheap on the wallet. so.... sometimes its probably best to get a 20 bucks item that performes 80% instead of a 100 bucks item that performes 100%.
I'll grab one but wouldn't expect a world of a difference in improvement. but you'll stiffen up ur chassis on the front nevertheless.
the only problem with these bars is if you have a intake, the bar won't fit (at least with a AEM CAI). I bought a cheap one and had to return it because of that. For the front, the only ones that do fit to my knowledge are Neuspeed and DC. For the back though, it should be fine.
Search and Learn
Quote
[hr]Originally posted by: Firewall
the only problem with these bars is if you have a intake, the bar won't fit (at least with a AEM CAI). I bought a cheap one and had to return it because of that. For the front, the only ones that do fit to my knowledge are Neuspeed and DC. For the back though, it should be fine.[hr]
ebay front strut bar work with aem cai also.
i bet you didnt try to put it like that
Ask me about your mom.
ok, sure it fits...but does it do anything?!?! For some of them, the shipping is more than the product!!! It seems a little too unbelieveable...
How do you guys like the bar?
I'm just not convinced that you can get the same results as the neuspeed bar with such cheap material. Convince me otherwise!
They will help stiffen up your car. However, if you go down the list of steps for suspension modifications, it goes
1. Tires
2. Springs/struts
3. Sway bars
4. Strut/torsion bars.
You won't notice much of improvement unless you have these done. It's like icing on a cake. The last step.
1. Tires
2. Springs/struts
3. Sway bars
Quote
[hr]Originally posted by: civicvtec1ps
[hr]
Quote
[hr]
Quote
[hr]Originally posted by: Roy
1. Tires
2. Springs/struts
3. Sway bars
You won't notice much of improvement unless you have these done. It's like icing on a cake. The last step.[hr]
1. Tires
2. Springs/struts
3. Sway bars
And it should be this:
1. Wider rims/Bigger rims(usually plus two -17 inchers; 17x8 w/45 offset is wonderful/tires
2. Dampers/springs/coils/strut bars/roll cage/floor bars
3. Sway bars/tie bars
Each has a cause and effect. You stiffen the springs, your unibody car will twist and twist some more. You get strut bars, you stock springs/dampers will dive more into the turns. Unless you know how to control that, I would not suggest driving on three wheels yet. Funny how you have to change more than one things. But I guess this is for people who care about performance and their car.
KillerX
Apr 9, 2017 08:20 AM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
