KONI QUESTION
Old Jan 2, 2003
wizawaza's Avatar
wizawaza is an unknown quantity at this point
KONI QUESTION
What did everyone cut there front struts too, the diy says 40 mm, and the directions say 7mm thats a big differece, so what did all of u do?
Old Jan 2, 2003
666's Avatar
666
666 is an unknown quantity at this point
I lost my directions but I am 99% sure they said 40mm. If it was any shorter I don't think the shock would slide in properly.
Old Jan 2, 2003
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
GOOD THING YOU POSTED THIS...HERE IS YOUR ANSWER...... straight from the KONI guy...
"Gordon Benson" <gbenson@koni-na.com>
Laurence,
We do not have a complete front struts available for the 2001 Civic. The
installation is not difficult if you take your time and work through the
instructions carefully. A general English write-up of the instructions can be
found on our website at
LINKAGE TO BETTER INSTRUCTIONS
This will be the same as your installation except for step four. In the
instructions included with the inserts, you have to
-Measure the distance from the top of the strut insert to the bumps on the side
of the insert
-Take this measurement and subtract 7mm from it. This is the amount that you
need to take off from the top of the factory strut.
If you have any other questions about the installation, please let me know.
Thanks.
Gordon
Old Jan 2, 2003
wizawaza's Avatar
thanks alot for the help, so what did u end up cutting them?
tuvok
Sep 25, 2015 03:13 PM
junkyardguy
Sep 2, 2015 06:07 PM
cukaracha
Aug 29, 2015 05:27 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
