Car makes funny sounds with E-Brake on
Old Dec 29, 2002
bootlegskwirl's Avatar
bootlegskwirl is an unknown quantity at this point
Well, got my car back from Racing Concept (for those of you who read my last post) but there's a couple problems with it. First off, they broke my tie-rod (or something related to tie-rod) and they need to get the part from Honda. However, the car is driveable. 2nd, whenever I put my e-brake on when I'm on an incline, and i rock the car a little bit, it squeaks. It didn't do this before, should I be worried about this? Could the tie-rod or lack of a camber kit be the problem?
Old Dec 30, 2002
eXNBP's Avatar
eXNBP is an unknown quantity at this point
I forgot what the reason of it is, but it has to do with the springs making the chassis more stiff and rigid [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 30, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
My car does that too, it's probably just rust or something on the pads for the drum, or on the drum itself.
Old Dec 31, 2002
dru106's Avatar
ThE CoRRupToR
Yes its normal. It happend to me too. Its just rear drum and pad that are against each other when the E-brakes are on. So when u move the car the brake and drum slips a bit making it squeak. Pull the brake hard then i shouldnt do that or if it still does I woulnt worry about it
Old Dec 31, 2002
nytejade's Avatar
Quote
[hr]Originally posted by: dru106
Yes its normal. It happend to me too. Its just rear drum and pad that are against each other when the E-brakes are on. So when u move the car the brake and drum slips a bit making it squeak. Pull the brake hard then i shouldnt do that or if it still does I woulnt worry about it[hr]
Is there an echo in here ?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ej8
Apr 13, 2015 06:36 PM
01civicboi
Bolt-on Engine Performance
Nov 2, 2001 07:33 AM
