Ingalls Camber Kit Directions
Old Dec 19, 2002
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
For the people who installed their own ingall camber kits...is it the same exact specs and directions as the SPC ones listed on this site? I have an Ex Civic and plannin to install the front and rear today. Anyone have DIY for ingalls camber instead of SPC or is it just about the same. Thanks
Old Dec 19, 2002
VNlilMAN's Avatar
The Standard One
it should be, i dont see why it would be different. both the front your replacing a bolt and both the rears are replacing the control arm.
Old Mar 7, 2004
MeguiarsEM's Avatar
MeguiarsEM is an unknown quantity at this point
What tools are needed for the install?
Old Mar 7, 2004
macrossranma's Avatar
macrossranma is an unknown quantity at this point
another question, do front camber kits work on coilovers with slotted bolt hole (kw v2)?
thanks
Old Mar 7, 2004
VNlilMAN's Avatar
The Standard One
Not much... just basic 14, 16, 18mm sockets. i forget which ones exactly... i used the stock iron on some of them.
why do you need it for slotted bolt holes? its slotted so that you can change the camber without needing an additional camber kit
Old Mar 8, 2004
MeguiarsEM's Avatar
What tools is need to adjust the camber?
Old Mar 8, 2004
VNlilMAN's Avatar
The Standard One
front, same the basic 14,16,18mm sockets. i forget.. to adjust the front camber just
1) loosen the stock one
2) loosen the aftermarket and when you start to turn it, the camber will start to adjust
3) tigthen both bolts back once you've found the camber you want it at.
rear, all you need is a wrench. sorry not sure what size, couldnt find one big enough. I just used those adjustable ones...
1) loosen those two nuts on the camber kit
2) turn the middle part to adjust it to the camber you want it at
3) tighten those 2 nuts back
but ya the alignment shop should do all this for you.. i wouldnt really recommend you eyeballing it
GolNat
Jan 12, 2021 09:06 PM
Donahue
Sep 8, 2015 09:00 AM
RIPSAW
Aug 16, 2015 12:14 PM
